Baratza Sette 270 Single Dose Considerations
* Do you have to have the hopper in place for it to run?
*If so, what ideas for a custom small single dose/smaller profile hopper would you suggest, may be something with a nice wooden cap?
*Is there an issue with a few beans getting trapped between the hopper and burrs?
I have it on pre-order and was wondering about these.
- Almico
I think it won't be difficult to made a custom hand made single dose hopper with wood or even 3D printed (S/steel is one step further...)
Looking at how many users will have this grinder there will be a lot of mods around there soon !
PD: thanks Almico for the pics!
Thanks for the pics and ideas. I'll be thinking about this... wood may be the easiest starting out.
Baratza could make extra $ if they were to offer a nice single dose hopper.
- PacMan
It would not be too hard to design and 3D print something for the Sette. The one I made for my preciso took a few tries but was pretty straight forward, even with nothing more than a tape measure for measurements. If I end up getting a Sette I will definitely print a mini hopper attachment.
Hmm, I wonder if buying an extra hopper, cutting short, and making a wooden lid may be the simplest way of doing it. Hopefully, those would be available before too long.
- another_jim
I single dosed with the stock hopper; and it worked extremely well. Any mods would be purely aesthetic. Like all Baratza grinder, there is a tab on the hopper and a microswitch in the unit. You will have to use a wad of paper or a shim to defeat it.NBA wrote:* Do you have to have the hopper in place for it to run?
Jim Schulman
- canuckcoffeeguy
I've always single dosed my Vario without issue. I just use the stock hopper. I get the odd popcorning of beans, but not a big issue for me.
The Sette is so blazingly fast it expels grinds like a rocket booster. So perhaps popcorning is negated by the downward sucking motion of the rotating outer burr. But I'm speculating since I haven't used one.
Is a single dosing hopper even necessary with the Sette? I expect no. But others who've used it would know better than I. Jim says it's fine.
I think it may not be necessary if no beans get stuck between the hopper and burrs. It's more of an aesthetic minimalistic look pursuit.
- Almico
Partially ground beans will always be lodged in the burrs if not single dosing.
