Aligning a 2015 Mahlkonig EK43 - Page 3
To measure that surface, you want to mount it on the shaft so you can rotate it around the mounting surface.
- Jeff
I'm not thrilled about the "Last Word" indicator's probe not being at right angles to the surface being tested, but it at least shows how the Titus tooling works.
(Being at an angle reduces the reading on the dial -- to about 70% at 45°)
Sorry what did you mean by "last word"?
- Jake_G
LMWDP #704
- Jake_G
Does that brace fit tightly into the slot in the motor shaft?
LMWDP #704
I was going to use foil around one end to help it fit more snug.
- Jake_G
It needs to not move at all (relative to the shaft) to be useful.
Foil might help, but I'd look into a hose clamp or something similar to really hold the brace onto the shaft.
LMWDP #704
Makes sense. I wonder if anyone has 3-d printed a device to hold the indicator in place
