1Zpresso J-Max a new kid will arrive on the block - Page 2
- Supporter ★
Blog post and "first look" video from the Coffee Chronicler:
https://coffeechronicler.com/1zpresso-j-max-review/
"It's not anecdotal evidence, it's artisanal data." -Matt Yglesias
- GregoryJ
A burr coating does not make it more aggressive, in fact the ones with dark coatings on them that I have tried (Feldgrind, Kinu) are on the slower side. The main purpose of coating is for longer lifetime.wojtowip wrote:Looks like the same burr as JX, but coated. That would mean it's probably bit more aggressive and would grind faster, but with more effort. Very interesting indeed.
You are correct, looks like I ate some words. I meant more aggressive than the JE models, since those are a bit slower to feed and easier to grind on vs JX.
LMWDP #694
- GregoryJ
I had a JE-plus, and I agree. It's extremely easy to turn, but takes a long time. Also the diameter was a little large (or maybe my hands are too small ) so after grinding 2 shots in a row, my hand holding the grinder was a bit tired.
1Zpresso has so many models now, most people can find one that meets their preferences. I think they are finding which features are the most popular, like the external adjustment ring and magnetic cup, and putting it into the J max. Maybe they will pare down their lineup a little bit in the future.
My unit just came in from Amazon today ahead of schedule.
Some initial after using the JX-Pro for a few months:
- The first thing I did was to try to calibrate to zero... which would've been more straightforward if I'd bothered to grind some beans to figure out which way is a finer grind.
- I have what I think are very medium-sized male hands and I found the finger space for turning the JX-Pro's dial a bit tight, which is a non-issue with the external ring on the Max. I do also find the JX-Max's seating screw easier to unscrew for calibration.
- My initial reaction was being upset in not realizing that it's 9 numbers/rotation rather than the current JX Pro's neat 10. I got over it in a few minutes but I'm into neat numbers. No shaker cup.
- The catch cup fits well in a Flair Pro 2's funnel and perfectly into an Aeropress.
- Coming from the screw mechanism of the JX-Pro, I do need to hold the unit a bit higher up to not risk unseating the magnets.
- I don't feel particular benefit from the included grip band so far.
- The beans don't sit on the adjustment dial like with the JX-Pro.
- I only used the JX-Pro for about three months as a backup so I can't say either have seen long enough use for me to make any comments on difference in taste from the burrs.
- It might feel like it grinds a little faster but I'm putting that down to new toy feel.
- The grinder arm is a little longer but I didn't notice a difference in use (yet).
- I really wanted the travel case. The included brush has a stiffer side which is much welcomed. The blower is a nice touch, it looks less weapon-like than the Giottos Rocket Blower I use for cameras.
- I don't grind over 20g at a time so I don't have any observations on max capacity.
- The first image shows how fewer pieces there are to reinsert upside down and mess up in reassembly, I felt much more nervous seeing all the parts in the JX-Pro when I first took it apart.
