Need to identify burned resistor in PBC for Breville 870 series
Have espresso BES870CBXL with coffee grinder that a has burned R37 resistor on the main circuit board that I need to replace. It basically exploded and I can't identify its value. I'm hoping to find someone out there with the same circuit board that can send me an image and/or tell me the colour bands of this resister. Then I will need to discover what caused it to blow.
There is an article on a sticking solenoid valve that is controlled by this resistor, so I will need to find it and check it. Or it could have burned from moisture buildup on part of the circuit board. I've see other posts with water leaking on the pcb, but all the electronics on this board is protected with a clear film and its also located in a plastic white case. So I can't see how this would have caused any problem.
Anyway my goal is to replace this resistor with the same one or better if required. Looking forward to your replies. Thank you.
