Dialing in SSP 64mm Unimodal v1 (Brew)
Hello.
I don't have these burrs but here's a question...
Internet seems to agree that these v1 burrs (less fines) are somewhat more difficult to dial in compared to v2 (tiny bit more fines).
I assume this refers to pourover as well. If so, please help me to understand why they would be more difficult to dial in.
A couple of wild guesses.
Is it because the good tasting extraction yield band, as measured by a refractometer, would be more narrow? Let's make up an example - say for some particular beans the best flavours appear around 20.40-20.60% for v1 as opposed to much wider 19.00 - 21.00% for some other burrs?
Or are they more difficult to dial in because the resulting EY tends to be less repeatable / more random from one brew to another. Even if all the input variables looked pretty much the same, you might get 20.00% in one brew, and then 21.00% in another?
Or the EY is very repeatable for the same recipe, but the taste will be unpredictable for the same EY from brew to brew?
Any other reason I can't think of?
Hope the question makes sense Thanks.
I haven't used the v2, multi-purpose burrs. Nor do I have a refractometer accurate enough for brew.. But:
- I do not find the unimodal v1 burrs difficult to dial in for espresso.
- they're definitely not difficult to use for pour over.
@Jonk - yeah, for espresso that makes sense, many people seem to point out that low fines burrs perform particularly well for faster kinds of shots
@Jonk - thanks for the feedback about your experience with v1 for pourover, it seems the dial in process was fairly typical for you
@Acavia - just to be on the clear side, is that based on your actual experience with v1 for pourover?
Thanks for your replies, @Jonk and @Acavia. As a newbie I've always found it a bit challenging to wrap my head around quantifying/defining "difficult to dial in". Glad to learn from both of you.
- EvanOz85
Anyone with these burrs able to pull traditional 9-bar shots with light roasts, or just mostly lower pressure turbo-style shots? Having trouble dialing these in on my P64 and I'm pretty much at burr touch.
I can easily pull traditional 9 bar 1:2 shots, both with an Ode and Mazzer Mini E at 1400RPM using uncoated SSP unimodal V1 (well seasoned) and nordic roasts (well, the Ode doesn't like it..)
- EvanOz85
What basket are you using? I was using the Unifilter with a paper filter which may have just been too much in terms of flow for the burrs.
I've had a set since 2019 and find them very forgiving in a variety of brews- v60, 155 and the chemex/ bonavita set up I use in the AM when it's too early to be competent with hot water. My favorite home cook recently put down her cup of a home roasted Yemeni/Sumatran blend and announced it was the best coffee she had ever had. Love em, but I leave the espresso to the Vario and Niche. This will likely get me off my ass to dial in espresso with them. If I do, I'll report back.
Oh, I use a Robot basket. With pre-infusion I think it uses a grind roughly equivalent to a VST basket in a regular straight 9 bar machine without a paper filter.EvanOz85 wrote:What basket are you using? I was using the Unifilter with a paper filter which may have just been too much in terms of flow for the burrs.
