What cues do you use to determine which variable to adjust - grind, dose, temperature?
I know there are many articles and videos, but would love to hear from folks on here - how do you decide which variable to tweak after pulling a shot?
For example, I have a medium roast I'm sipping straight this morning. 20 gram in, 40 gram out. It's good. I'd give it a B. Body is nice, decently thick, with good aroma and flavor. But, there is a hint of bitterness/dryness on the finish that lingers longer than I'd like.
Would you - grind a tad coarser? Reduce output? Reduce input? Lower temp?
Curious what flavor or other cues you all use to determine which variable you're going to adjust.
I know you didn't necessarily want links to more websites/videos, but I have always found the "espresso compass" charts shown in these websites/videos to be very helpful when trying to dial in espresso shots. If you haven't seen/tried using them, I'd recommend giving it a go!
https://lifestylelab.ca/dialing-in-brev ... -machines/
https://www.google.com/search?q=espress ... 13IV29pp8M
- guijan12
If it was my machine and known batch of beans, I would probably grind a little bit coarser.dmau9600 wrote:.....20 gram in, 40 gram out. It's good. I'd give it a B. Body is nice, decently thick, with good aroma and flavor. But, there is a hint of bitterness/dryness on the finish that lingers longer than I'd like.
Reason is I already know the sweetspot and strenght, ratio and other variables are in balance.
It only needs a little tweaking.
Regards,
Guido
Guido
- baldheadracing
Well, the topic is covered in the first two "stickied" posts in the "Tips and Techniques" forum, and covered in extreme detail in the FAQ's.
For shortness of response: Dialing in espresso by Gwilym Davies [short PDF]
There is also the James Hoffmann YouTube series if you'd prefer a video presentation instead of text: http://www.youtube.com/playlist?list=PL ... U1b73w1BUW
To answer your specific question, I would change nothing and pull a second shot and see if the taste or any extraction parameter has changed. If so, then one of the shots may have had some random issue. I would then keep pulling to get consistent results first - before thinking of changing anything. (When starting from an unknown point, I always pull two shots before changing anything.)
Good luck!
Good luck!
This is VERY GOOD ADVICE. Especially if you don't have your puck prep dialed in to a very high level.baldheadracing wrote:I would then keep pulling to get consistent results first - before thinking of changing anything. (When starting from an unknown point, I always pull two shots before changing anything.)
If you can't pull two back to back shots that run within a second or two of one another for the same output to within maybe .3-.4g then you have more practice to do with your WDT.
Second shot, yes! I also monkey with ratios without changing anything else. Running a shot a little long or short to get a desired ratio gives a good idea of whether you want to go there. Then adjust variables to fine tune. Brewing a pour over or cupping also tells you what flavor you're aiming for, which may help you decide how to step through those charts.
LMWDP #716: Spring comes, and the grass grows by itself.
understand that any changes affect more than 1 parameter.
assuming ur technique and machine is consistent enough to produce same tasting shot within +-1s and +-0.5g~..
and changing just one variable.. likely give you these results.
less yield = less bitter + less aroma + stronger acid/sour.
grind coarser = less bitter + weaker shot + more sour.
lower temp = less bitter + less flavor + weaker shot + less notes/sweetness.
more dose = slower shot hence less yield, different flavor balance, usually need grind change to avoid choking.
imho try less yield or less temp.
I'm rapidly eliminating variables. I have a roast I love, a good grinder, and an old used espresso machine. I also have a Bunn commercial grinder for 'morning' coffee from a Cuisinart coffee maker. So now I no longer even adjust the espresso grind! The setting I now have works when the beans are fresh enough. When they age past that point, I toss them in with the "morning grind" beans and procure a fresh bag of espresso beans.
My time for a shot is 28 seconds, and in that time the cup should fill to a certain point. If it is full to that point in say, 25 seconds, then that's the last shot with that bag. I'm getting great consistency.
