UK parts list: Mignon Specialita Single Dose Mod
Firstly all credit to @dak for this mod. Everyone know his amazing post and video here: Eureka Mignon Specialita Single Dosing Modification
But I found it hard to get the parts for his mod in the UK and spent a lot of time searching for the right pipe and O-ring.
So I thought I'd post a list here to make it easier for anyone else in the UK. Pics attached. I went for a turkey baster just for aesthetics. It doesn't work unless I also have the square O-ring / gasket in place to cover the 1/4mm gap left between the grinder collar and the pipe..
Gasket - 40mm internal diameter, square profile with a groove on the underside
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
Pipe - 1" plain pvc socket - perfect for an 18 gram dose. Can fit up to 20 at a push.
https://www.plasticpipeshop.co.uk/1-Inc ... p_623.html
Turkey baster - pricey one off amazon just because...
https://www.amazon.co.uk/gp/product/B01 ... UTF8&psc=1
(you can definitely find the baster cheaper and most standard ones will fit in the pipe - but I liked the look of this one and it's very thick rubber so I hope will last)
Now have seriously zero retention and it just takes a couple of pumps on the baster handle to push through the remaining grounds with the grinder running. Thank you @dak.
Total cost - 17.50 GBP
First post - so go easy on me.
