Steam wand modification for Izzo Alex Duetto IV
Is it true that the "no burn" steam wands perform worse? If so would it be easy enough (and worth it) to remove that inner lining from the wand and get a rubber grip, or do I need to purchase a whole new steam wand. Machine is Izzo Alex Duetto IV Pro. I have pretty good steam already (steam boiler pid set to highest), but if it's easy enough I wouldn't mind upgrading the steam want away from the no burn version. Maybe it's not even worth it though... Thoughts and advice welcome TIA!
I found the "burn" version an improvement - but YMMV! I replaced the "no burn" wand with a SS one as the cost was not too bad. If you go "burn" make sure you get the little rubber finger protector for the wand -- the wand gets "burn" hot.
- BaristaBoy E61
I can make very good micro foam with the stock no-burn original Izzo Alex Duetto steam spigot. No-burn is an obvious advantage. Not having it might also mean a steam wand that's harder to clean if not immediately attended to.
I see no reason to change if steaming pitchers no larger than 50cl.
