Breville Dual Boiler Low Pressure on Shots
Hello!
New here, relatively new to home espresso. I'm on my second machine (not counting the super automatic), and recently upgrade my old GC to a secondhand Breville Dual Boiler. I've been pulling shots for a day or two and noticed that the pressure is always a bit lower than 9 bars. I'm sitting at more like 7.5ish, or thereabouts. Blind basket test (I have a metal one, not the silicon one included with the BDB) puts me at a hair under 9. I've read that a blind basket normally will leave readings at 10.5 bars. With that said, I think my Baratza Vario does need a better calibration. I was producing some fines on my GC so I'd really like to try and do a hyperalignment with it, maybe that will make a difference.
I just bought this thing so I'm really hoping I don't have to replace the pump. I've tried doing the wiggle thing with the portafilter, but haven't done a full cafiza backflush (not sure this is a good idea on a Breville).
Any ideas on how to fix this? Just one other thing to note, I only notice the solenoid "sneeze" after pulling the shot, so this makes me dread that it's a faulty pump.
A used BDB? The PO may have adjusted the OPV. It's really not necessary, IMHO. At any rate, if you get 9 BAR with a blind filter, you should be able to get 9 bar with a fine enough grind to choke the machine. If you can't grind fine enough to choke or get over 7.5 BAR then your grinder is the problem.
I would open the BDB and see it it still has the OEM OPV. whether is is the original OPV or not, it should be adjustable. Adjust it up to 9.5-10.5 BAR.
9 bars with blind on a BDB but not pulling = grinder or bad quality/stale beans. BDBs group pressure readings are accurate. So either Vario needs recalibration or your using poor quality beans, 1 or the other (or both). I still have two Varios from 2011, have other grinders, but one is aligned with steel burr and other aligned ceramic. I used that thing for espresso for yeeears single dosed (chute flap flipped), think I always kept it calibrated in 2 range.
What beans/roaster are you using?
As far as back flush not sure why your worried about that? I blank flush after every session, and than about every Sunday I do a flush with some cafiza. And than periodically you'll get the clean me notification, just put some cafiza in basket and let it do its thing (it's like a 300 second or something like that system that will flush and dwell automatically at different timings). Even doing my normal flushing routine and I use chemex filters I cut with circular cutter to fit on top you'd be surprised what comes out after the clean me cycle. I don't descale as I use custom water recipe but even than I'll drain the boilers (920) periodically just to see.
