Question: Mixing the same coffee beans over different grinders
After reading many comparison on grinders after they get dialed in (like flat vs flat, or conical vs conical and conical vs flat or the hybrid flat+conical).... but a question appeared... randomly in my head:
What happens AFTER they dialed in then you grind 1/2 of the beans on both machines then mix the grinds together (or a mixture depending on the taste in question), do you get both clarity AND depth (if conical and a flat mix)?
Then also what happens if you layer the flat grinds on the bottom while conical on the top, and vice versa vs the full mix shake.
I myself dont have such a setup no where near it... nor experienced even if I did, so I can only ask people here.
- baldheadracing
I'd guess the worst of both worlds; less clarity and less depth, etc.
However, there's a limit to what I'll do for a consistent cup of coffee, and mixing grounds - or sifting them - is beyond what I'll do in the morning .
shifting is one thing I wont do.... but putting 1/2+1/2 or 2/3+1/3 or 1/4+3/4 though an automatic grinder is really not much more work if you already have more than 1 grinder (it might be faster actually, and less heat)
At 50/50 you might be right.... but i suspect there is a declining rate of return which you can trade off (the 1/3+2/3 and the 1/4+3/4)
- baldheadracing
The actual grinding is not the issue.RedPanda wrote:shifting is one thing I wont do.... but putting 1/2+1/2 or 2/3+1/3 or 1/4+3/4 though an automatic grinder is really not much more work if you already have more than 1 grinder (it might be faster actually, and less heat)
Designing and executing a sufficiently good experiment is much more work than simply grinding and tasting. Not doing the experiment properly is only going to confirm what you, or I, expect to taste.
- yakster
Imagine the struggle to dial in the shot for flow rate and taste when your working with the output of two different grinders in the basket.
-Chris
LMWDP # 272
LMWDP # 272
