La Marzocco Linea Mini upgraded control board - does temperature adjustment wheel still work?
- BAEvans
Quick question:
When upgraded with the Wi-Fi enabled control board, does the Mini still have the temperature adjustment wheel?
Longer answer:
Yes.
The app will override the wheel if you change the temp in the app.
If you turn the wheel again after changing the temp in the app, the wheel will override the app again...
I always change the temp with the wheel, and uses the app to confirm the chosen temp.
Yes.
