Profitec Pro 800 Review - Revisited
- HB
- Admin
I miss the "before" times when we had regular group taste tests at Counter Culture Coffee's training center in Durham, NC. I also miss serving a crowd to test an espresso machine/grinder combo under load as I regularly did at a local car dealership and occasionally at my regular work location. Sigh!
Regular site members may recall that I reviewed the Profitec Pro 800 almost six years ago. ECM, the parent company, has updated it with several cosmetic upgrades and a couple maintenance upgrades:
As it turns out, this aligned with with my employer's encouragement to return to the office. I agreed to have a small "welcome back" espresso day, if only as a good excuse to return to one of my favorite espresso machines, the Profitec Pro 800.
The turnout was modest, a combination of regulars and some interns who just started the day before. I was joined by my colleague Martin Keen; he's the guy behind the well-established The Homebrew Challenge on YouTube and the more recent Keen on Coffee (more on that later).
Below are some action shots with Martin. For the actual group service, he was in charge of steaming and I took orders/pulled the espressos. Over the course of 90 minutes, we served around 20-25 drinks at a leisurely pace. It was great fun! Some of the participants complimented the drinks. One remarked "This is the best cappuccino I've ever tasted." While I could accept this as high praise, I should qualify it by pointing out that the typical attendee is likely a national coffee chain customer, so it's not a high bar to clear.
Martin is still working on his latte art skills, so I jumped in for this photo. It's not an exceptional pour, but at least hints at a rosetta.
- Profitec joystick levers for steam/water
- Bigger steam boiler gauge
- Wood handles for portafilters, steam/water knobs
- Base in stainless steel
- Boiler can be removed without removing the front panel
- HB (original poster)
- Admin
Here's a quick intro video Martin and I filmed the same day as the "welcome" session:
- Admin
As a tip of the hat to Phillip of Newbie Introduction to Espresso fame, Martin has offered to step in with a beginner's perspective. I was especially interested in hearing his impressions of the Profitec Pro 800, since I argue that it's one of the most forgiving espresso machines around. Here's his video:
An excellent good explanation of the mechanics of the brew temperature management. He also points out that the volume of a commercial lever espresso machine is much greater than many home lever espresso machines and you'll need to adapt your technique accordingly. There's no need for a Fellini Move here (search if you're curious what that is)!
- Admin
A question about the noise (or lack thereof) for a plumbed in Pro 800 came up in Profitec Pro 800 plumbing/PID issue; reposting my response before for easy reference.
It's not silent, but it's definitely quieter than the vibratory pump. I believe the sound is from the water rushing through a vary narrow inlet. I tried cutting off the water supply to check if the noise was a "buzzing" solenoid as suggested in this thread above; the noise immediately stopped.
Note that the owner's manual calls out operational pressure of 2-3 bar:
That's about ~40 PSI max, which is lower than most home water pressure of 50-55 PSI. The Pro 800 in the video above is on our third floor, so the effective line pressure is ~2.5 bar.Profitec wrote:The boiler is filled by the line pressure, if you are using the Pro800 with a fixed water connection. The pump is not activated when using a fixed water connection. Make sure that the fixed water connection of the machine is hooked up to a potable water supply with an operational pressure of 2 to 3 bars. Please note that the pressure of the water supply may not always be consistent. As soon as 3 bars of pressure are occasionally exceeded, install a pressure reducer.
- Admin
One of my New Years resolutions is finishing the reviews I started in 2022.
Last week I did some temperature measurements with a Scace I thermofilter. It's a little trickier because the steam boiler pressure that fills the brew chamber is enough to start the flow immediately, which impacts the reading because the Pro 800's heavy group has less time to dampen the temperature. To get a more realistic estimate of the temperature profile, I manually stopped the flow for a few seconds to simulate preinfusion by blocking the thermofilter exit (NB: Don't try this at home, you could burn yourself).
Since the brew water originates from the steam boiler, it's not surprising that there's a big temperature spike:
This is very similar the "humped" temperature profile of heat exchanger espresso machines, but maybe a little flatter towards the end (i.e., the peak was 207°F and the temperature quickly flattened out around 201°F). I attribute that to the mass of the Pro 800's grouphead, which is really, really heavy even compared to the E61's grouphead.
