Hot vs Cold Portafilter/Grouphead
How big of a difference does it make to extraction times?
People say run 2-3 blind shots through a portafilter but I worry about just going through my water tank so quickly on my machine.
Thanks!
Thanks!
The bigger 'concern' is affect on extraction temperature. A hot pf will not be such a heat sink and give you better maintenance of desired temperature throughout the shot.
LMWDP #748
- BaristaBoy E61
Our portafilter is always in the group when the machine is 'ON' and sits in the group after prep while a cup full of freshly drawn hot water is also heating up before the shot is pulled.
My preference is for max temperature stability, group, portafilter and cup.
