Adjusting the Bezzera BZ10 pressurestat?
If I want LESS pressure, do I turn it clockwise or anti-clockwise?
Thank you.
Thank you.
- HB
- Admin
Would you post a photo? I don't know the specific pressurestat your espresso machine uses. How to adjust an espresso machine pressurestat offers general recommendations. FWIW, of the espresso machines I've used, I recall that clockwise = more pressure.
Almost certainly counter-clockwise on the P-stat's adjustment screw for less boiler pressure... But a photo or at least the brand-name would help.
Thank you for the responses. The set screw is visible through a small hole. In order to produce a photo, I'd have to take the covers of the machine off, which is what I'm trying to avoid by posting the question here. In any case, through trial and error, I found the pressurestat on the BZ10 is increased (i.e. more pressure) by turning clockwise. An 1/8 turn results in a 0.1 bar change.
