Rocket Giotto Help
New here but I need some help repairing my Giotto, if possible. I recently had gotten water inside my machine and it shorted the circuit board. I replaced it and the relay. It now turns on and the pump works but it does not heat up or pressure up. Any suggestions?
Thanks
Thanks
- BaristaBoy E61
Welcome to HB.
Have you checked to see if there is a red reset button on the boiler that might have tripped?
Double check the electrical wiring.
Be sure the machine is unplugged while doing this!
So I tried that advice and it did not work. The button is in the depressed position. I had someone look at it and they said voltage is now going to the boiler/heating element. Would that need replacement?
Thank you
Thank you
- BaristaBoy E61
You would have to measure the resistance across the heater element leads with a digital VOM after removing one of the element leads for an accurate measurement to be sure.
Please unplug the machine before doing anything!
