Anyone tried a glass Kalita Wave dripper as a Melodrip/Gabi/Hario drip assist type tool?
The tools, such as Gabi Drip Master, Hario Assist, and Melodrip, are made from plastic. I am not comfortable using plastic with hot water and would prefer not to do so if possible to avoid. I am not trying to argue that point, I just want to put it forth as the reason I am thinking about using a glass Kalita Wave as such as tool because otherwise, I assume someone would ask why not just use one of those.
I have used V60 as main brewer for over the last year-plus, but now using a Kalita Wave 185. That got me thinking I could use a Kalita Wave as a drip assist, holding it above a V60, while pouring into The Kalita Wave with kettle. I'll test it, next time I use a V60.
Anyone already tried it?
I've not tried it but I do have a Gabi a, b and a melodrip. I think the water would pour much faster from a kalita. I would think this would disrupt the bed more but who knows
- happycat
HB has a great search function.Acavia wrote:The tools, such as Gabi Drip Master, Hario Assist, and Melodrip, are made from plastic. I am not comfortable using plastic with hot water and would prefer not to do so if possible to avoid. I am not trying to argue that point, I just want to put it forth as the reason I am thinking about using a glass Kalita Wave as such as tool because otherwise, I assume someone would ask why not just use one of those.
Kalita wave + V60 flow control
LMWDP #603
- yakster
I once tried to make a Wave like brewer out of a cupcake pan, but it didn't work too well because the filter would stick to the bottom. You might try this kind of idea with lots of little holes to simulate a melodrip.
-Chris
LMWDP # 272
LMWDP # 272
Thanks. I thought of Espreso Bloom but being metal it would reduce the temperature of the water a bit I assume.
something cheaper would be a phin filter or Vietnamese dripper. I've only seen metal ones so it might not work as well as you desire but they are a lot cheaper than stuff like an espro bloom or kalita wave
