Fresh roasted coffee acting strange
- chuckclaunch
I've been roasting for 6-7 years, and have a fairly new to me (a few months) Vivaldi S1V1 espresso machine. I roasted a Brazilian Dry Process Amecafe Cooperative today, and I often like to try the roasts fresh out of the roaster. I usually use about a 18g dose, but noticed with this coffee the dose seemed huge and volumetrically a lot more than the previous roast I'd been on for a couple of weeks that was dialed in. I had to back my Niche grinder off to 22-24 on the dial just to get any flow, and even then it was barely coming out. Clearly I need to set the dose size back but I haven't had to do that in months. Do any of you ever find that a freshly roasted coffee dose size is different than one that's rested a bit? I did also notice an odd stream coming out of the group (see video here). Any thoughts?
If it's a new bean then it's the bean not the roast (generally speaking), my PNG and my Guatemala are dialled in at two difference settings on my Niche (but roasted by me).
- Jean
- HB
- Admin
Yes, I've noticed that the grind setting for ultra fresh coffee needs is slightly coarser. I assumed it was because of the extra oils and CO2 (?). If you grind the coffee and let it sit out for ~5 minutes, it behaves more like fully rested coffees.chuckclaunch wrote:Do any of you ever find that a freshly roasted coffee dose size is different than one that's rested a bit?
Clean the screen? Level the espresso machine? As long as there is an overall flow across the dispersion screen (and it appears there is), I wouldn't worry about it.chuckclaunch wrote:I did also notice an odd stream coming out of the group... Any thoughts?
- chuckclaunch (original poster)
I appreciate the replies everyone, I'll keep fiddling with it. I think the different bean is a major part of it as I still had a little of the previous roast leftover and that one pulled just fine. Thanks!
I've never noticed the coffee changing volume over the course of resting. I definitely need to adjust grind as it ages. I think I usually tighten my grind up as I go along ... I cant remember, lol.
As others pointed out, the beams themselves make a big difference. A 15g of a less dense Brazil may overfill my portafilter, while 15 g of a super dense Ethiopian may underfill.
Roast level also makes a difference. A darker roast may plump up your beans more. Also, the darker roasts need a coarser grind to flow/extract right.
Bottomlone is ... listen to your coffee. If it's too full or choking the machine, downdose and/or open up your grind.
Different beans will definitely throw off your dial, I normally don't have to adjust much if it's the same beans fresh or not unless it's really old but that's just me.
- Jean
