'Flush and go' technique suitable for smaller HX machines?
quar
#1: Post by quar »
Hi All,
Anybody have any thoughts on using the "flush and go" technique vs. the flush and wait technique on a smaller HX machine, like the Anita?
I started out using the flush and wait technique detailed in Dan's Stop Worrying and love the HX article, but after a couple of months, transitioned over to the pro-style "flush and go" flush. I seem to remember being happy with the results, but unfortunately close to a month of down time due to repairs, so I really can't remember. Since getting everything fixed up, things seem to be running a little on the sour side. I'd been blaming in on the blends that I'm trying being a little brighter than I prefer, but am starting to wonder if it's something else. After thinking about it for a while, I'm wondering if this technique is just overwhelming my Anita and the temp is dropping too low during the latter part of the extraction.
Mike
Admin
#2: Post by HB »
Some advocate the "flush and go" approach, notably JonR10 and Chris Tacy (he called it the "pro's method" in early drafts of his equipment writeups), rather than the flush-rebound-go method described in the HX Love article. I've tried both methods and in most cases, they are nearly equivalent. The essential difference is the flush-and-go method is surfing to the desired brew temperature and very quickly starting the extraction, the flush-rebound-go method is surfing slightly past the desired brew temperature and rebounding back to the desired temperature. While it may seem a bit odd at first, I found that consistency for small HX machines was more easily obtained "surfing up" because it occurs more slowly (15-25 second rebound) versus "surfing down," which relies on more precise flushing and no dawdling.
Either approach would work with the Anita, which I assume works just like the Andreja. If you want a leisurely pace and a wider window of error, try this: Reduce the boiler pressure to 1.1 bar (top of cycle) and flush to the end of dance (~206F) + eight seconds (one degree / second). Then allow enough rebound time to taste, probably around 20 seconds to arrive at ~202F with a slightly humped profile. Otherwise the flush-and-go should be more like flush to the end of dance (~206F) + six seconds and no more than 10 seconds before starting the extraction. Of course these timings are just estimates... you'll need to adjust by taste.
PS: Related comments in Boiler pressure setting - influence on the cup? excerpted below:
chelya wrote:Why would one choose to adjust the pressure?
HB wrote:Abe mentioned it in his review - to allow a different range of temperatures on HX machines, pressure can be adjusted. That made me curious.
Abe's review described brew temperatures ranging from 91C (195.8F) to 96C (204.8F), a range which his Giotto wasn't able to deliver at the same boiler pressure by flushing. Practically all the coffees that I work with are brewed in the narrower range of 198F (92.2C) to 204F (95.6C), with the majority in the ~201-203F range. A four degree range is well within the sweet spot of most HXs simply by adapting the flushing amount. You can add a couple more degrees to that range by switching to the flush-and-go technique ("pro's method"), but as Abe pointed out, it requires more skill to nail a precise temperature consistently, especially for the smaller HX machines.
Keep in mind though when reading these discussions that boiler pressure is only one variable that determines an HX machine's thermodynamics. The size of the HX, the percentage immersed in the water versus steam, the deliver tube lengths, group design... all of these contribute their part, so it's folly to draw precise instructions from general advice about HX machine operation. For example, the article How I Stopped Worrying and Learned to Love HXs really speaks to E61 / HX machines; the steps its advocates apply vaguely to the Cimbali Junior and not at all to the Elektra A3, despite that they are both HX machines. There's differences among prosumer HX machines too. The flush routine for the Andreja Premium would apply in principle to the Expobar Lever, but fails miserably in the specifics (the Lever has a much longer flush and it rebounds much faster at the same boiler pressure setting).[/quote]
malachi
#3: Post by malachi »
Keep in mind that the extraction profile will differ. So you'll likely find that one gives you a result in the cup that you prefer for some coffees.
What's in the cup is what matters.
JonR10
#4: Post by JonR10 »
heh heh - looks like I'm chiming in late... :roll:
Very often I advocate the flush-and-go method because I feel like some folks will benefit like I have by exploring the lower end of the temperature curve. To me, it's all part of developing a familiarity with one's machine. I think this is a key (in my own experience) for making more enjoyable espresso at home.
Developing a "feel" for my machine's operating characteristics lets me make temperature adjustments "on the fly" and often without thinking about it very much at all. It starts (for many) after finding bitterness in the cup. I have found (after helping a few people) that many folks do not understand how quickly some HX machines recover and/or how much water needs to be flushed before running the shot.
If my first shots (of a new roast or blend or bean) have an edge then I'll flush more or wait less.
If the shots have any sourness then I may wait more or flush less (or both).
If you really want to accelerate the learning curve for your machine, then take some temperature measurements.
  • Measure the temp of the flush itself.
  • Measure a "blank" shot pulled immediately after an 8-ounce flush (from idle).
  • Measure the water temp 20 seconds after an 8-ounce flush (starting from idle).
  • Measure the water temp 40 seconds after an 8-ounce flush (starting from idle).
  • Measure the water temp after flushing 8 ounces, then waiting 30 seconds, then running a blank shot then wait a full minute then flush 2 ounces then run the blank shot and (you get the idea)
It's not a prescription. Just take a few measurements at different conditions to develop a feel for how your machine behaves and then adjust for taste.
It works for me....
(and now I need to go paste this in the Pallo Tool thread!) :idea:
Admin
#5: Post by HB »
JonR10 wrote:Developing a "feel" for my machine's operating characteristics lets me make temperature adjustments "on the fly" and often without thinking about it very much at all.
Thanks Jon for chiming in, you bring up a very good point: Although all this minutia may sound daunting, it really isn't that difficult to develop the skills for excellent HX temperature control. Initially a newbie may be all over the map, getting within no better than a 4F range of their desired brew temperature, but most will halve that after a week or two of practice. I believe it's fair to say that someone who's mastered the routine is within a 1.5F range. Thanks to the jumpstart the thermofilter gave me while evaluating the Elektra A3, I was routinely within 0.5F of the target temperature - when I took the trouble to measure (admittedly that machine makes it easier to nail precise temperatures).
BTW, I was talking to AndyS recently and he commented that he thought I favored HX machines over double-boilers. Given the amount of time that I spend writing and talking about them, I see how he would come to that conclusion, but actually I like both for different reasons. No argument that temperature management of a double-boiler is easier. However, I don't think HX machines are the poor design compromise some would argue. I can twiddle temperatures shot-to-shot on the fly to suite a particular blend without delay, plus I genuinely believe some blends are more tasty with the "humped" temperature profile (it seems that lighter, fruity, aromatic blends fall in this category). That's consistent with Chris Tacy's and Jim Schulman's comments, but to be quite honest, I don't have their depth of experience to speak conclusively (and besides, I don't like speaking conclusively :?).
quar (original poster)
#6: Post by quar (original poster) »
Thanks for your replies everybody. Glad to know that I'm probably not overwhelming the machine. After finally managing to get my autofill problem sorted out, I guess I'm still being a little overly cautious that there aren't other problems lurking somewhere. Mostly paranoia that I managed to damage the element before noticing that my boiler wasn't refilling. Overtemp thermo never popped or anything though and it comes up to pressure OK.
Sounds like it is the brightness of the blends that I've been using that I'm tasting and not actually an underextracted sourness. Went back over my order history and I was tasting this in these blends before having any issues. I'll have to try a different flush profile with these blends to see if I can mute this somewhat. Once I get back in town, I'll have to take some temp measurements as well.
Mike
Admin
#7: Post by HB »
quar wrote:I'll have to try a different flush profile with these blends to see if I can mute this somewhat.
Although my preference for brighter blends has grown the last few months, I would try adding an extra 5-10 seconds to the rebound to attenuate the brightness (a "high hump" temperature profile). I believe that a rebound of 25-30 seconds is the upper boundary for the Andreja / Anita before it will scorch the puck at practically any boiler pressure setting.
malachi
#8: Post by malachi »
If you're finding blends to be too bright (not too sour, but rather exhibiting more acidity than you normally like) I would suggest that the best option is to change coffees.
If this is not an option for some reason, I've had far better results with technique changes than with temp changes. Upping the brew temp (even for a percentage of the extraction profile) with the brighter coffees tends to lead to a thin and often harsh flavour note. You might, instead, want to try going with a larger dose and a lower extraction volume.
#9: Post by quar (original poster) »
malachi wrote:If you're finding blends to be too bright (not too sour, but rather exhibiting more acidity than you normally like) I would suggest that the best option is to change coffees.
Yeah, I'm starting to think that I just managed get a couple of brighter blends. The first is a 50-50 post blend of Harrar Horse and DP Sumatra Mandheling. The other is Espresso Elite from coffeewholesalers. Both are new to me as I usually drink Espresso Monkey Blend or MBG. Thanks for the advice on updosing, I'll give it a shot.
Mike
hperry
#10: Post by hperry »
I've been lurking a fair amount during these discussions and am awed by the temperature stability that some are able to obtain with HX machines. I have a Bezzera BZ40 - which is a larger machine, but shares a strong family resemblance to the Pasquini Livia. Using the Scarce device I can repeatedly hit a given start temperature using a variety of the techniques to maintain a given temperature. From there, however, during a 25 second pull there is an 8 to 15 degree temperature variation from start to finish. I watched the Elektra (I think) movie where there was only a minute variation during the shot. Settings are 1.1 and 9 bar. I suspect this indicates a fundamental flaw in my methodology - but also wonder if the machine itself may be flawed.
HB wrote: Thanks Jon for chiming in, you bring up a very good point: Although all this minutia may sound daunting, it really isn't that difficult to develop the skills for excellent HX temperature control. Initially a newbie may be all over the map, getting within no better than a 4F range of their desired brew temperature, but most will halve that after a week or two of practice. I believe it's fair to say that someone who's mastered the routine is within a 1.5F range. Thanks to the jumpstart the thermofilter gave me while evaluating the Elektra A3, I was routinely within 0.5F of the target temperature - when I took the trouble to measure (admittedly that machine makes it easier to nail precise temperatures).
Post Reply
