Chloride in Water - Recommended Acceptable Ranges
- CarefreeBuzzBuzz
I have LM(0-30), and Synesso (0). Slayer isn't specific. I am interested in collecting recommendations.
Can anyone post a screenshot from owners manuals of any major manufacturers recommendations:
Dalle Corte
Londiunium
Decent Espresso
Lelit
ECM
Others
Thanks
Dalle Corte
Londiunium
Decent Espresso
Lelit
ECM
Others
Thanks
- homeburrero
Hi Michael,
The only one I've come across that you don't have is Kees. Here's from a recent Slim Jim manual:
They agree with LM-USA about 30 mg/L chloride. It's interesting that they also give a relatively low sulfate recommendation of 0 - 50 mg/L, but the really odd thing is that they have a 30 mg/L sulfate target. I don 't get that -- may be a goof. They also have an unusually conservative silica recommendation.
With respect to La Marzocco, I think LM USA newer advice is relatively consistent about picking 30 mg/L for max chloride, but not always true for manufacturer's guidelines. the Linea Mini Operator Manuals are more lenient, allow 0-50 mg/L chloride. Here's a snip from the v1.2 11/2015 manual:
The V1.1 operator manual was the same for chloride, but recommended oddly high hardness numbers (90 - 150 ppm) that was probably a goof. Their 1.2 manual now recemmends those numbers for TDS.
And Synesso used to recommend 0 chlorides, but the newer manuals have loosened up on that. Here's for the 7/2016 version of the MVP MPV Hydra Owners Manual:
They still make clear that any chloride may be harmful, exactly as Professor Pavlis has advised here on HB. When they say 5-15 mg/L max chloride I think they are perhaps implying that in some cases 5 may be the max chloride. (For example in blended RO that comes out at low pH and low alkalinity.)
Pat
- CarefreeBuzzBuzz (original poster)
Pat thanks for the thorough update. You rock!
I had the old numbers so the updates are great.
interesting post... i checked the izzo alex leva manual and it doesn't even have spec in regards to chloride...
LMWDP #663
- Jeff
I didn't know it off the top of my head, but 1 gpg ~ 17.1 ppm.
