How to make your Mazzer dose like an Anfim - Page 2
- RegulatorJohnson
hey.
i love the schnozzzzola!
i use a glue stick instead of tape. i will be adding the wire immediately!
i have a doser microswitch and would like to respect myself but cant figure out how to get it out, without major damage to the major.
found it 'yo. Mazzer Kony - removing doser microswitch instructions
thanks.
jon
thanks.
jon
2012 BGA SW region rep. Roaster@cognoscenti LA
- shadowfax
My thought was to butt the fins/sheets up to where they are flush with the bottom of the dosing chamber, so the star will knock any coffee off the top of them as it goes by. I can still imagine there may be some problem with a little coffee sticking to the sides of the sheets. I will report back when I get a chance to go to a hardware store and get some sheet metal to try this out. I'll have enough extra to make a metal schnozzola if things go south, of course.AndyS wrote:It might cause problems with coffee getting stuck in the there, but it sounds worth trying.
Nicholas Lundgaard
Great mod! I was thinking of doing something similar to my new Cimbali Max Hybrid, which seems to suffer from really bad clumping for some reason. Would the wire trick work on the Max's doser, I wonder? There's more plastic and less metal, so it might not be grounded and so might not reduce static much. I guess for the price it's worth a shot.
Lock and load!
- RegulatorJohnson
i have not seen an anfim up-close.
what makes an anfim dose like an anfim?
does it have similar wires in the chute, etc?
jon
jon
- AndyS (original poster)
I don't know all the tricks but here are a few:RegulatorJohnson wrote:what makes an anfim dose like an anfim?
1. The doser has "snap action." As you pull the handle, the starfish inside snaps at a certain point to complete its move rather than progressing smoothly through the stroke.
2. Exit hole of doser is funnel-shaped (gets smaller as you go down)
3. Yes, there is a wire in the chute (pic below)
-AndyS
VST refractometer/filter basket beta tester, no financial interest in the company
