Spinning for distribution? - Page 2
What about creating some sort of distributor device that works similar to the Versalab so that you dose from your grinder into a container and then dump that into the distributor with the portafilter underneath? Something like an electric sifter but one that wouldn't destroy the grounds or heat them up. I'll see what I can come up with as far as an illustration but it might be an idea, although extra bulk in the prep area.
RogerB wrote:Centrifugal force is indeed a fiction. Centripetal (from the latin, "center seeking") forces are "balanced" by acceleration, and the illusion of centifugal force is due to the tendency of any object travelling in a straight line to continue travelling in a straight line unless acted upon by an outside force (Newton's Third Law).
Centrifugal (from the latin, "center fleeing") force, if real, would portend that the yo-yo you're swinging around your head, once released, would travel away from the circle's center radially, when in fact it departs tangentially; that is, perpendicular to the radius of the circular path it was travelling only a moment before.
As for spinning the filter basket...
...I think we're overthinking it.
I think you explained it better than I did. There's the fictitious centrifugal force, which isn't really..a force, but merely a reaction to the change of direction, which still feels like a force. then the 'real' force is that which the object exerts on the ..container, as it changes direction (in this case a circular path)...This is a coffee forum, not a physics one. I should shut up (since there are plenty of people who probably know more than me on this subject anyway )Celebrian wrote: But the centrifugal force isn't....real as such. i mean, it feels real, but it's all relative.
Let's say that you're in a car and it takes a sharp bend...the passengers may feel like they are thrown to one side of the car, when in reality, there is no force acting on the passengers, but reacting to the acceleration of the car....(blah blah...relativity...blah...physics).
I think we're overthinking everything.
coffee tastes good.
hey, why doesn't someone test this spinning thing out? i mean, it wouldn't hurt to try. we just need to find something that would spin it. like a lettuce spinner with prongs. or..something. you never know unless you try.
you're welcome!The_Mighty_Bean wrote:Thank you so much for bringing back my nightmares from the physics class in college where the class average was in the 40s. An important part of why I switched from pre-med to pre-law.
-Alex
Spresso_Bean wrote:What about creating some sort of distributor device that works similar to the Versalab so that you dose from your grinder into a container and then dump that into the distributor with the portafilter underneath? Something like an electric sifter but one that wouldn't destroy the grounds or heat them up. I'll see what I can come up with as far as an illustration but it might be an idea, although extra bulk in the prep area.
So, check it out. I am not crazy. Okay, I am, but in a good way.
There are many specialties that are interested in achieving even particle density, besides our own. It turns out that the term of art for particle density in airspace is called "bulk density". Then when you start settling the grounds, you get what is called "tapped density", and if the grind is even then the maximum tapped density is reproducible for individual substances.
There is a scientific device which does this, and measures the density. It's called an Autotap. Here is a quote from the brochure. http://www.quantachrome.com/density/autotap.html and click on the PDF for the brochure.
Now, check it out-- from the same brochure. Page 2:handling or vibration of particulate material causes the smaller particles to work their way into the spaces between the larger particles. The geometric space occupied by the powder decreases and its density increases; Ultimately no further natural particle packing takes place without the addition of pressure and maximum particle packing is achieved. Under controlled conditions of tapping rate, tap force drop and cylinder diameter, this condition of maximum packing efficiency is highly reproducible.
So, rotation of the powder, plus some sort of vibration action known as "tapping" will produce a distribution of maximized, even density, with a flat surface. A consistent, reproducible distribution that could be used to limit variables in comparing espresso experiences. (Hi, AndyS... you out there?).Reading of the powder surface is facilitated by automatic rotation of cylinders during tapping which promotes a flat powder interface.
There it is, the holy grail. Now just add something to create a side-seal- either a level tamp or preinfusion, and your extraction will have zero distribution-based flaws.
The question is, what exactly is "tapping" vibration-- EDIT- it is literally a piston "tapper" inside a cam shaft, stroking at a high speed (hush, gutter minds) to create a very steady and even agitation.
...and is it possible to create a rotating vibrating thingy that securely holds a PF basket, and is cheap enough and practical enough for the home barista
If the device costs as much as a Versalab, then there's no point. Do it for $50 or less, and I think you have a new product of the year. Ahem, all rights reserved.
Salad spinner cut down and glued to a dental vibrator?
~tMb
I'm interested because it seems to do to things i like:
1. Get me a good side seal
2. Get me slightly less density in the center. I always shoot for a slightly less dense center because as i tamp, most of the tamping force will be used to compress the outside of the basket, and seal the sides better. Usually this means something as little as working from the outside in when doing the WDT.
I don't think a machine could be devised to do it cheaply, quickly, and well. But hey, get Joe Behm working on it.
Spencer Weber
- RegulatorJohnson
i wonder how many shots in a average day on the planet earth get pulled successfully, without using these types of gizmos and techniques and such.
jon
jon
2012 BGA SW region rep. Roaster@cognoscenti LA
I've been looking at all sorts of strange devices on Ebay, including dental devices that spin and vibrate and apply vacuum suction from below.Spresso_Bean wrote:What about creating some sort of distributor device that works similar to the Versalab so that you dose from your grinder into a container and then dump that into the distributor with the portafilter underneath? Something like an electric sifter but one that wouldn't destroy the grounds or heat them up. I'll see what I can come up with as far as an illustration but it might be an idea, although extra bulk in the prep area.
I ran a quick experiment on vibration today. I dosed a double basket naked PF 3/4 full of scrap grounds in a clumpy heap. Then I applied fairly strong vibration to the bottom from a plug-in Homedics back massager, which had a flat attachment, on which I rested the basket
The grounds settled in, with fines being drawn downwards and clumps gravitating towards the top. Occasionally the mass of grounds began a rotating motion in the basket. I'm not sure what caused that kind of translation- whether it was related to the precise angle at which I was holding the basket (because the other end of the massager is rounded, it was tricky to keep it perpendicular to the floor at all times), or whether the vibration was just not quite strong enough to consistently spin the grounds.
Anyway, I found that without rotating the PF, I did not end up with a flat surface. When rotating it as far as my range of motion would allow, which was back and forth, by hand, over a range of about 270 degrees, I got closer to a flat surface. Also, even with something the strength of this plug-in massager, an unacceptable amount of clumps remained atop the settled grounds.
This leads to further questions:
If the vibration is strong enough to spin the mass of grounds, does that eliminate the need for a separate rotary mechanism?
Would even stronger vibration break up the last of the clumps (it seems like it would, having watched the process at both low and high intensity vibrations). If so, is it more practical to up the vibe power, or to have to include some sort of stirring/sifting process (as mentioned by SpressoBean) in addition to the spinning and vibration (sounds like a PITA)
It would be interesting to hear from the folks who have experimented with dental vibrators.
~tMB
P.S. I don't know Jon, why do some of the most experienced people here bother with Fluke thermologgers and Scace devices? Distribution is nearly as important as temperature, and not everyone has a Versalab, or a pocket-size Tim Wendelboe to do a consistently perfect Stockfleth's. I'm just looking for simple, cheap, practical methods to make better espresso more consistently.
- Psyd
Not that many, as a percentage. I have to get my fix at way to many coffeeshops around the country that just 'grind and pull' and don't have any tricks and treats to their coffee and their techniques, and end up serving black squirt.RegulatorJohnson wrote:i wonder how many shots in a average day on the planet earth get pulled successfully, without using these types of gizmos and techniques and such.
I think the very reason that we get better shots amongst the HB'ers is that we're ready to try (nearly) anything and everything to get it that eensy bit better.
My mantra? "If it works, keep it." It costs me nearly nothing to try most anything that someone can come up with, and if it makes my morning coffee easier or better, I'm game.
I am not, however, building a centrifuge for my baskets. ; >
Espresso Sniper
One Shot, One Kill
LMWDP #175
One Shot, One Kill
LMWDP #175
I've been following this discussion for a while (and almost jumped in with the "there's no such thing as centrifugal force" bit! ), but... While I haven't tried it, I DO have one of those small dental vibrators.. Got it years ago when my dentist got a couple of new ones "thrown in" with a larger equipment purchase. I've tried it for mixing paint (watercolor [or watercolour if you're a brit! ], acrylics, etc) as it seemed like it MIGHT help with reagitating (sp?) liquid paints that had been sitting for a while (and the pigments settled out). worked, but took a LOOOOONG time to do it... 'Twas easier to just shake it! I also have an industrial ultrasonic cleaner which will agitate at about 80Khz (I seem to remember it's freq is something like 88Khz, but don't hold me to it!)... I doubt EITHER would do a good, even dispersion of coffee grinds without a LOT of assistance...
On the paint bit, I finally built a small paint shaker out of a 3volt DC motor and some small brass parts (gears, etc) with a simple vise to hold the bottle... works great and takes about 20 seconds to totally mix the paint (that way my airbrushes don't clog as often! )
Steve C.
I'm having an out of coffee experience!
LMWDP # 164
LMWDP # 164
Well then, we could just dose into the basket, slap a blind basket on top to compress the pile down, hold it in place and then shake it up! Quick levelling swipe (or tap, if underdosed), lock and load.ntwkgestapo wrote:'Twas easier to just shake it!
I wonder how that would work. It's not necessarily going to be as consistent as vibrating to max tapped density, but it still might yield a great distribution.
I can't readily try it because my blind basket is the two-dollar rubber nipple variety. Anyone want to give it a go, and see how it compares to WDT?
Bertie seemed to differ on that point. More testers needed, I guess.ntwkgestapo wrote: I doubt EITHER would do a good, even dispersion of coffee grinds without a LOT of assistance...
Would your paint-shaker work?
~bean
I've been reading this for a while trying to figure out if I could add anything and the last comment made me wonder if getting rid of the last few clumps would actually do anything and trying to think of a test that might answer the question. My doserless Macap clumps something awful and stirring with a needle helps, but only somewhat so I've no way to try the clumpless test. But I wonder if someone with a Versalab or a similarly clump free grinder could try this? No idea if it's meaningful, but maybe it is.
Have 2 identical baskets at hand
Measure 2 identical doses of beans into some suitable container
grind one of them into one of the baskets and tamp lightly
Hold the 2 baskets together and tap the empty one on the table so all the tamped grounds fall into the empty basket
Grind the second dose into the now empty basket
This should leave you with one almost perfect and one really badly clumped doses of identical coffee.
How do they compare?
I realize it's a badly flawed test, but it's easy to do and might answer some question or another.
Ira
Ira
