Solubles Yield as a function of Grind and Dwell Time - Page 3
- cannonfodder
Here is a question; does conductivity change as heat changes in a solution? I am inclined to say yes based a couple of observations. So if you were going to use a TDS meter to check solids in shots between grinders not only would the dose/time need to be very close but the tested samples will need to have cooled to a predefined temperature. I would also agree with Jim in that the 3 way will suck some moisture back out of the puck so simply tossing a used basket on a scale has limited accuracy. JimS and Andy did a lot of work on this and baked a lot of espresso puck brownies in the process.
Dosing and Solids Extraction Retraction
Aspects of Espresso Extraction
As to the Clover, my two cents (disclaimer, I have only had a couple cups from one so take my opinion with that in mind) it makes a good cup of coffee. I have had better and I have had worse, would I pay $10K for one, nope. I would be more inclined to get a case of French presses and vac pots to be used at the table but it is a very cool gadget to watch. But then so is a vac pot.
Yes, they will vary roughly 1% to 2% for every degree of Celsius change that occurs depending on the meter. Some meters possess a function to compensate for this, but you need a baseline to start with.cannonfodder wrote:Here is a question; does conductivity change as heat changes in a solution? I am inclined to say yes based a couple of observations. So if you were going to use a TDS meter to check solids in shots between grinders not only would the dose/time need to be very close but the tested samples will need to have cooled to a predefined temperature.
