Bottomless portafilter = more volume - Page 2
I talked with local master today at favorite shop, they liked using the bottomless in their training help with getting tamp right. They also really liked using the bottomless PT as a daily test to see if the automatic settings and grind were correct on their monster 4 head machine.cannonfodder wrote:I have been mulling around the idea of getting a bottomless PF. Not because of the added 'volume' in the shot but as a diagnostic aid. I have also seen reference to its ability to produce a thicker, buttery mouth feel (bonus!).
I have a crazy project zero budget going on in my basement...the bottomless PF I drilled out has really help diagnosing problems...(don't even go there)
Don't for get the fun/different/neat factor.
- cannonfodder
I had mentioned this in a discussion on coffeed.com, I actually prefer the shots pulled from my single spout portafilter over the bottomless. While it is a very good learning tool (I use it when working on a new blend/technique/machine/grinder etc...), my normal go-to portafilter is a single spout. I prefer the texture of the crema better.
The bottomless produces a larger bubble in the crema (using my eye to judge) and gives a different texture. I prefer the finer texture of my single spout; I think I get a silkier texture in the cup. The large bubbles also give the crema artificial thickness vs. the finer textured bubbles of the spouted PF. That could account for most of the volume difference between a spouted and bottomless shot.
- Psyd
Access to a drill press and a 2 1/8 to 2 1/4" hole saw, and you're in business. A coupla DWS to hold the PF top-down on a piece of wood, and center the pilot bit on the spout hole, and thirty seconds later (even on a slow metal speed) your through!cannonfodder wrote:I have been mulling around the idea of getting a bottomless PF.
Round off the now sharp edges (careful, they can be sharp enough to draw blood, DAMHIKIJK) and take it to the kitchen!
Espresso Sniper
One Shot, One Kill
LMWDP #175
One Shot, One Kill
LMWDP #175
I think you two must have missed the date that the quoted text was posted.
I even remember Dave's how-to for the naked PF with a drill and/or Dremel, and nothing else.
"Pro" coffee roaster. Ex barista trainer, competitor, consultant.
- Psyd
EEK! Yeah, I think that I did. I was wondering..Jasonian wrote:I think you two must have missed the date that the quoted text was posted.
I never want to see another connect-the-dots kind of bottomless technique again, though. The drill press and the hole saw were so cheap and easy that I could never consider drilling two dozen holes and sawing them together again.
Espresso Sniper
One Shot, One Kill
LMWDP #175
One Shot, One Kill
LMWDP #175
- cannonfodder
Yup, it was a little tedious and if I had to do it again, I would use a hole saw, or just buy one. They are readily available for any machine out there now. But I still prefer the spouted PF over the bottomless.
I am glad someone else noticed this. My friends who I pull shots for think I am insane for noting the difference.cannonfodder wrote:I had mentioned this in a discussion on coffeed.com, I actually prefer the shots pulled from my single spout portafilter over the bottomless. While it is a very good learning tool (I use it when working on a new blend/technique/machine/grinder etc...), my normal go-to portafilter is a single spout. I prefer the texture of the crema better.
I personally think that your insanity puts you in some pretty good company.
