Roasting Profiles for Espresso?
- Compass Coffee
Generally speaking my espresso profile targeted for straight shots runs 2 to 4 minutes slower than various SO roast profiles for "coffee". (Even though coffee usually means espresso brewed Americano or cappuccino.) Currently I've stuck with pre-roast espresso blending rather than more advanced and or time consuming multiple roast multiple profile post roast blending.
The espresso roast profile I've been using for a while now is:
200f @ 1 minute (Initially hit the heater hard to 150f @ ~25sec then back way off)
250f 2
275f 3
300f 4
320f 5 with continued straight 20f/min ramp to
400f 9 minutes (my usual start of 1st point, sometimes a few earlier)
410f 10 with continued straight 10f/min ramp to
440f 13 then slowing ramp
445f 14
450f 15 end of roast ~FC touch of 2nd, very few initial droplets on very few beans (with pre-roast blend)
and in roaster cooling
200f 2 minutes
100f 4 minutes
At one time used a 30 second to 1 minute final temp hold without slowed final ramp before ending the roast as I saw Stumptown do with their Hairbender roasting. Tried the very slow final 2 minute stage and liked the results just as well so have stuck with it. Though if my final stage runs a bit fast I'll still add a bit of a final temp hold before cooling.
This is Caffe' Rosto roasting with my desired very slow bean movement rather than fast like typical fluid bed roasting. Temps measured with temp probe about 1/3 down into bean depth green about middle as they expand, 1/2# batches.
FWIW this profile is very similar to the one I developed to tame the acrid tendency of Kenya Mika noticed by Jim during that particular 4 way roast exchange we did back Summer '03. Those roast exchanges we did were fun and great learning experiences!
250f 2
275f 3
300f 4
445f 14
200f 2 minutes
100f 4 minutes
Mike McGinness
- mattg
What type of profiles are you trying to achieve by dropping the temperature toward the end? My attempts at running a lower temperatures for the final 3-4 minutes have ended up with a profile that muted most of the flavors and tasted almost baked.
hi...just wondering if that cool down cycle of yours is a bit long...I roast via CO/UFO combo...I dump into colander, and have room temp beans in less than 2 minutes...for a 1 lb roast....Compass Coffee wrote:Generally speaking my espresso profile targeted for straight shots runs 2 to 4 minutes slower than various SO roast profiles for "coffee". (Even though coffee usually means espresso brewed Americano or cappuccino.) Currently I've stuck with pre-roast espresso blending rather than more advanced and or time consuming multiple roast multiple profile post roast blending.
200f 2 minutes
100f 4 minutes
[snipped]
I commend you on your attention to your roast...I would give this hobby up if i had to go through as many temperature machinations as you!
I've read the Rosto is a fine way to roast....almost bought one, but I go through 1.5 #'s of espresso and 2#'s of vac/drip coffee in a week in my home/studio...thus the combo serves my needs...
Back on topic...I bet Jim could give us a hint as to which beans...say A Daterra Brazil, Harar (dry processed), Monsooned Malabar, Yemen, Sulawesi, etc could be roasted in combo!...what say you, Mr. Jim?
- another_jim
I'm sort of fixed on
0 - 1 min to 250F (basically top speed)
1 - 4 min to 300F (drying phase, an absolute must)
4 - 7 min to 380F (top speed again, the longer you're here, the worse it tastes)
7 - 11/12 min to the end, 11 for brewing, 12 for espresso (balance fast vividness and slower sweetness)
But I'm now experimenting with an extra step, slowing down to 10f per minute through the first crack, and speeding to 15f/min afterwards. I'm hoping this will produce a better tradeoff of vivid and sweet. It'll take a few months before I can decide.
Jim Schulman
Jim- what temp do you shoot for here?another_jim wrote:7 - 11/12 min to the end, 11 for brewing, 12 for espresso (balance fast vividness and slower sweetness)
- another_jim
Depends. 425F for cupping (5F over the end of the 1st crack); 440F for espresso tasting (5F before the first pops of the second); then to whatever roast level I think will work for that bean and prep method.
As a general note: these profiles are machine specific and have to be calibrated to each machine's crack ranges as measured on each machine's thermometry. My crack range is: first crack from 395F to 420F, second from 445F to 455F.
Jim Schulman
- Compass Coffee (original poster)
Lately I've been thinking along similar lines. Currently getting great sweetness but perhaps lacking in acidity definition. Ideal might be doing two separate roasts of my straight shot blends, one faster one slower like with your excellent WTC blend and roast of a few years ago.another_jim wrote:But I'm now experimenting with an extra step, slowing down to 10f per minute through the first crack, and speeding to 15f/min afterwards. I'm hoping this will produce a better tradeoff of vivid and sweet. It'll take a few months before I can decide.
Alternately try reducing my final stage by a minute speeding up the end. Thinking of comparing three finishes: One as is profile above, another going from 440 to 450f end of roast in 1 min instead of 2 and a third going from 430f to 450f 1min instead of current total 3 minute. I'm going to do this in the next couple days and send 1/4# samples of each to Abe to compare. (plus greens of the blend to roast his method since these will be Rosto air close but no cigar roasted )
Mike McGinness
Top speed of course is relatively to ones setup! If I went top speed with the Rosto (~132v to heater, ~144v to fan) and my 1/2# batches for a minute it'd shoot past 300f. For whatever arbitrary reason I've chosen 200f as my 1min mark, 250f two minute mark.another_jim wrote:I'm sort of fixed on
Same target temp @ 4min1 - 4 min to 300F (drying phase, an absolute must)
Here again top speed with a qualifier you've mentioned in the past, top speed while maintaining even bean color change. With my over sized slow moving 1/2# Rosto batches faster than 4 minutes to start of 1st from 300f usually results in too uneven going into 1st. But agree too slow will/can result in a dull roast.4 - 7 min to 380F (top speed again, the longer you're here, the worse it tastes)
I've come to the preliminary conclusion my current ~6min start of 1st to end of roast too long. Not baked, but not enough acidity definition or vividness as you describe I believe.7 - 11/12 min to the end, 11 for brewing, 12 for espresso (balance fast vividness and slower sweetness)
Did a roast of my espresso blend today changing two stage parameters from posted above: increased 300f to 400f ramp rate for 4min total time (was 5 min, 4min is actually my norm for most non-espresso roasts already), decreased start of 1st to end of roast from 6 min to 5 min using straight 10f/min ramp 400f to 450f end of roast. Likely won't test resulting shots 'til Sunday young 3&1/2 days rest then will adjust the three test roasts to split and send half of each to Abe next week accordingly. Of course could have should have done two roasts today each with only one changed stage but where's the challenge in figuring out the results from that!
Mapping today's roast profile realized I haven't done any serious profile experimenting since Dec '05, date on my current profiles sheet! Man time flies.
Mike McGinness
- another_jim
I'd be interested to know how it goes. My experiment yielded a too bright taste, but terrific aromas (unfortunately nothing like the taste, a bait and switch roast if I've ever tasted one). Getting the taste match the aroma will be my next job.Compass Coffee wrote: Did a roast of my espresso blend today changing two stage parameters from posted above: increased 300f to 400f ramp rate for 4min total time (was 5 min, 4min is actually my norm for most non-espresso roasts already), decreased start of 1st to end of roast from 6 min to 5 min using straight 10f/min ramp 400f to 450f end of roast. Likely won't test resulting shots 'til Sunday young 3&1/2 days rest then will adjust the three test roasts to split and send half of each to Abe next week accordingly. Of course could have should have done two roasts today each with only one changed stage but where's the challenge in figuring out the results from that!
Jim Schulman
- cpl593h
I did the exact same thing with some Daterra Yellow Bourbon and it was wonderful. It wasn't so great with anything else, but it did the trick for the Brazil.Compass Coffee wrote:Did a roast of my espresso blend today changing two stage parameters from posted above: increased 300f to 400f ramp rate for 4min total time (was 5 min, 4min is actually my norm for most non-espresso roasts already), decreased start of 1st to end of roast from 6 min to 5 min using straight 10f/min ramp 400f to 450f end of roast. Likely won't test resulting shots 'til Sunday young 3&1/2 days rest then will adjust the three test roasts to split and send half of each to Abe next week accordingly. Of course could have should have done two roasts today each with only one changed stage but where's the challenge in figuring out the results from that!
