Tamper bottoms: Flat or convex? - Page 2
Which is better? Tampers with flat or convex bottoms?
Flat
68
33%
Convex / domed
95
46%
No preference
43
21%
Total votes: 206
PeterG
#11: Post by PeterG »
I prefer flat.
I've always felt...the bottom of my pf basket is flat, so the tamper should be too. I don't want the center of my puck to be thinner than the edges, even slightly.
I also staub tamp, so I have always felt that the convex shape would do some weirdness in the middle, as Abe describes.
Finally, I can't see the convexness creating any lateral pressure, "sealing" the coffee to the sides of the pf. If anything, the opposite is more likely. Think of this scenario: you distribute and level the coffee perfectly in the pf. If you use a convex tamper, the middle would be slightly more compacted than the perimeter, leading to increased channeling there. To be sure, this is pure conjecture. But that's what bulletin boards are for, eh?
Ken's post does have me thinking, though, about engine piston design. All the pistons I have ever seen are slightly convex. And if it's good for my Hemi, it might be good for my Faema.
Peter G
Ken Nye
#12: Post by Ken Nye »
I've got the crew at the shop working with flat for the next week or so, I will report any interesting feedback.
espressobsessed
#13: Post by espressobsessed »
I've noted some seriously flawed thinking within this thread. There are many ways to dose distribute and tamp to achieve one end: a technically flawless shot.
1. First flaw: not choosing the piston to match the showerscreen. If you're runnning a curved showerscreen, you want your tamper to match that curve, so you can maintain that 2mm gap across the top.
2. Some baskets will become curved, some are less prone. The 18g LM basket seems to be the best, the 16g Rancilio - not so much. Curving in the basket will cause problems, but you can compensate for them with your distribution.
3. A curved piston WILL NOT reduce channeling on the perimeter - that is, depending on your dist. technique. If your distribution is perfectly level, then a curve will pack coffee in the centre more densely. That dense coffee will reach it's maximum tamp faster than the outside.
My last swipe in distributing creates a slight divot in the coffee bed. My tamper is the Reg European curve: I tamp to create a bias in the centre: when I watch my extraction at work, a canadian dollar sized brown spot appears in the centre of the bottomless PF, then continues outward. I find this technique lets me run shots longer before blonding. Since switching to the euro curve, I've stopped using the staub.
I should also add, I get the most consistent results when using a hydraulic Rancilio. I've used procon machines - I find them to be less forgiving: flow pulsates, channeling occurs (generally) more often. (yay hydraulic)
Moral of my story: tailor your tamper to your showerscreen (and whatever yields the longer shots and most consistency)
espressobsessed
#14: Post by espressobsessed »
I also highly recommend BURNING your clicker tampers.
If you want them as a learning tool - they're FAR different than regular tampers. The violent action of the click at the end is not natural (and also causes a pressure spike). Use a bathroom scale instead, then you or your baristi can see the pressure progression during the duration of the tamp.
The only reason why clickers are popular: everyone loves a gimmick (usually).
-j
shadowfax
#15: Post by shadowfax »
espressobsessed wrote:when I watch my extraction at work, a canadian dollar sized brown spot appears in the centre of the bottomless PF, then continues outward. I find this technique lets me run shots longer before blonding. Since switching to the euro curve, I've stopped using the staub.
speaking of flawed reasoning....
when your shots start in the center, they almost always blond first in the center. The reason your shots "take longer to blond" is that the outside starts late. then when the center starts to blond and overextract, the outside of the flow is still brown and hides it. This is why your shots appear to blond later.
as for tamping, there's so much variance that I hardly buy any of this. you will buy a tamper, and then adjust your method to it. the convex of the tampers I have seen is minimal anyway... when you distribute, it's not based on getting absolute evenness in terms of density across the puck. You distribute to compensate for how your shots run. in other words, if I notice that my shots are starting on the outside, I will attempt to get more coffee out to the sides as i distribute using stockfleth's. It doesn't matter if you are using a convex or a flat tamp, you will end up compensating with your method, unless you just don't care. a tamper is supposed to provide a consistent surface to pack the coffee. if its curved, then you will need to have more coffee around the edges. And, based on feedback from the bottomless, you will do this whether you know it or not.
I don't know about the shower screen thing. I've never seen a convex shower head, although lots of groupheads have screws, and it's probably good to leave a little extra room in the center for that. but ultimately, I don't think it matters at all. equipped with the feedback of a bottomless portafilter, again, you will come up with a distributing/tamping method that matches your tamping surface to produce even extractions.
Or you just won't improve because you're lazy, and complain about how you wish you had a different type of tamper, because of course, if your espresso sucks, it's your equipment, not your technique, right? ;)
espressobsessed
#16: Post by espressobsessed »
Most e61 hx machines used a curved showerscreen. Maintaining an even distance is based on schomer's methods.
Caffewerks
#17: Post by Caffewerks »
espressobsessed wrote:I also highly recommend BURNING your clicker tampers.
-j
I just set a pile of them on fire! Yikes what a mistake ;-)
In real world training, take five people and ask them to tamp at 30-40 pounds. What you get is a wide spectrum of different tamping weight. Click tamps provide initial training to a set weight and that all.
Using one of these devices in a production enviroment is not what they were produced for ( speaking for my own product)
The violent action you refer to must be theory only. There was allot of work behind creating that little bit of kinetic energy and how to stop it before it travels. To be honest this was a concern but after 9 months or so, I have a different theory, and one that will be produced into another "Gimmick" tamp.
A bathroom scale is what brought about the click type tamp. A bathroom scale is intended for wieght measurement of 80+ pounds and tend to be inaccurate. The large spring in a bath scale is unstable until it reaches outside of its free space.
Anyhow, burning clicker tamps is one idea, but it is also flawed as they would be easier to simply melt. Then you could use the raw materials to design and build something better, ,,,.......Well if there was something better ;-) Until that time bath scales belong in the bath and click type tamps belong in the hands of those who need them.
Gotta go build the next gimmick, CYA......
buzzword
#18: Post by buzzword »
espressobsessed wrote:3. A curved piston WILL NOT reduce channeling on the perimeter - that is, depending on your dist. technique. If your distribution is perfectly level, then a curve will pack coffee in the centre more densely. That dense coffee will reach it's maximum tamp faster than the outside.
For a rookie, for a guy who's tasted good coffee and wants to make it for his family and (lucky) friends, that is very helpful. I posted on CG yesterday, asking advice on choosing the Euro or US curve in a Reg Barber tamper. No answers on CG yet, but this is the kind of word I was hoping for!
Also when obsessed wrote concerning 'clicker' tampers:
it was a useful consideration for me, cause that's all I've used since I moved from my Capresso C1000. I confessed on CG that I thought I might be getting better results with my plastic convex (the last day or two) that came with my Oscar. Not that I'm competent to judge the clicker-tamper myself, but obsessed provides good food for (my) thought.
The Espro tamper I've been using moves pretty smoothly though about 3/16", but then it does kind of pop through a final 1/16 or so.
malachi
#19: Post by malachi »
the clicker is a useful training tool. seriously.
would i use it to actually make shots? no.
but i used it in every training session i've done since it came out.
as for the flat vs convex thing... seriously, it doesn't make any difference that i can discern. i've cupped a whole lot of coffee from all sorts of tampers trying to taste minute changes. i've evaluated tons of shots through a naked portafilter trying to identify altered extraction. so far, there is a lot of theory - but at the end of the day it's what's in the cup that matters and i see no difference.
use what makes you feel good.
personally, i think handle length, balance and weight are all FAR more important that the shape of the bottom of the piston.
What's in the cup is what matters.
cannonfodder
#20: Post by cannonfodder »
I have one of each. Depending on the shape of the shower screen determines which one I use. My Factory lever has a flat screen so I use a flat tamper, my Millennium has a domed shower screen so I use a convex tamper. It just made more sense to me to use a tamper that matches the screen. That way you have an even height between the puck and screen from center to edge.
