Timing of extraction starts when? - Page 2
- HB
- Admin
Timing traditionally begins when the brew pressure is applied and the extraction lasts 20-30 seconds. Most commercial espresso machines have rotary pumps and they pressurize nearly instantaneously; the espresso beads on the bottom of the basket in barely 3 seconds. Most home espresso machines have vibe pumps and require 5-7 seconds before the first drops appear on the bottom of the basket. That may explain the differences you have read.
That said, once you get beyond the beginner stage, Jim's advice early in this thread is best:
another_jim wrote:Here's the proper rule: 0. Throw your stopwatch away. 1. Stop your shot by the color of the flow.
Understood. Well assuming I like the body, taste and look of my espresso, but I want more volume how do I do that? I imagine maybe a different OPV setting? (i've recently dialed it down from 10.5 to 9.5 bars).HB wrote:Timing traditionally begins when the brew pressure is applied and the extraction lasts 20-30 seconds. Most commercial espresso machines have rotary pumps and they pressurize nearly instantaneously; the espresso beads on the bottom of the basket in barely 3 seconds. Most home espresso machines have vibe pumps and require 5-7 seconds before the first drops appear on the bottom of the basket. That may explain the differences you have read.
Right now I am getting about 2 oz before my shot starts to blonde, and if I try grinding coarser to get more volume, the espresso gets to "thin". (my grind (MACAP), tamp (Auto 30# tamper), PID temperature are all constant)
- jesawdy
If you are happy with your espresso, why change? Back to back doubles ("quad-shot"?) would be my humble solution. Your other options are to try more coffee in combination with different and/or larger baskets.
Jeff Sawdy
- Psyd
Does 'brew pressure' mean pre-infusion, too? I never got very clear on that in the earlier discussion.HB wrote:Timing traditionally begins when the brew pressure is applied
I dunno, the stopwatch is a useful tool, when applied correctly. I start the watch at thirty seconds (actually, it's the timer on my microwave) and then go to the machine and start the pull. Once it's where I want to stop it, it is very satisfying to be reaching for the button to stop it, and then hear the timer go off. Of course, I usually check the timer as I turn of the machine, just to see where I am. It is a great indicator of how things are progressing.HB wrote:That said, once you get beyond the beginner stage, Jim's advice early in this thread is best:
I would never stop a pull based on a timer. I look at the shot. I've had some fifty second triple ristretti that have been out of this world. Sweet, great mouthfeel, warm and buttery with nutty.... er... I'll be right back...
'Kay, where was I? Oh yeah! Don't let the clock dictate, but you can use it as a measuring tool.
Espresso Sniper
One Shot, One Kill
LMWDP #175
One Shot, One Kill
LMWDP #175
- cafeIKE
Use a timer that counts up from 0:00, stopping the shot on color.
As PSYD says, fabulous shots occur in the 40's.
Two advantages of count up :
1 - No annoying beep. It's bloody annoying in a busy shop that uses timers to hear the incessant beep.
2 - Times the intershot interval. Over time, can be used to gauge how long a flush is required on an HX.
Ian's Coffee Stuff
- Psyd
Shop? How many HB'ers are pulling shots in their shops? If anyone tells em that the beep is annoying them, I simply turn, get all red in the face, threaten them with the naked PF, and scream (at the top of my lungs) "NO ESPRESSO FOR YOU! Come back, one year!" ; >cafeIKE wrote: 1 - No annoying beep. It's bloody annoying in a busy shop that uses timers to hear the incessant beep.
Espresso Sniper
One Shot, One Kill
LMWDP #175
One Shot, One Kill
LMWDP #175
- HB
- Admin
For many espresso machines, preinfusion is fairly high pressure (e.g., 4 to 6 bar), so yes, I would include it in the overall pour time. For a lever using only boiler pressure (1 bar), I wouldn't include it. However, this is only my opinion as I'm not aware of a hard and fast definition.Psyd wrote:Does 'brew pressure' mean pre-infusion, too? I never got very clear on that in the earlier discussion.
- cafeIKE
From Lattice Boltzmann model for coffee percolation:Psyd wrote:Does 'brew pressure' mean pre-infusion, too? I never got very clear on that in the earlier discussion.
Bottom Line : If it tastes well, do it.To prepare a 'good' espresso is not an easy task. Many variables can affect the quality of the coffee, such as water pressure and temperature, the amount of ground coffee, how hard it is pressed and (not less important) the practice of the barman. Evidently some of these parameters cannot be controlled in a scientific way, but, for those that can, a few optimal conditions have been empirically determined:
water temperature: inside the machine it should be about 88°C;
pressure: it should be a function of time with profile as shown in Fig. 1;
quantity of coffee: 7 g;
duration: the whole process should take 30 seconds;
production: at the end, we should have about 25 ml of coffee in the cup.
Ian's Coffee Stuff
- cafeIKE
"about 88°C" could be a poor translation from "at least 88°C"micki wrote:88°C ? That's a bit low ...
IIRC, generally accepted range is 88° to 96°C / 190° to 205°F
Ian's Coffee Stuff
