Zero cost adapter for portafilter pressure gauge
DaveGrayson
#1: Post by DaveGrayson »
After a little head scratching it occurred to me that I could make an adapter out of an old presta style bike inner tube valve stem that would be able to pass though the portafilter hole and let me measure pressure with a bike pressure gauge (to fit presta valves). Cut the valve stem out of an old tube (free), cleaned it, screwed it in place with the valve nut, and tried it with my bike pressure gauge. Success!!!
DaveGrayson (original poster)
#2: Post by DaveGrayson (original poster) »
more pics...
Advertisement
TomC
#3: Post by TomC »
Clever!
HeyHey
#4: Post by HeyHey »
You sir, are a thinker!
Cheers,
Chris
Christopher Scott
After Sales and Technical Support
LA MARZOCCO HOME
nhokt
#5: Post by nhokt »
Awesome!
After spending many years working in a bike shop we found countless uses for old tubes, never thought of this though.
bostonbuzz
#6: Post by bostonbuzz »
Brilliant. The only problem for me is that I don't have a metal gauge like that. My floor pumps will probably not be happy with boiling water filling their non-rated rubber tubes!
LMWDP #353
civ
#7: Post by civ »
Hello:
DaveGrayson wrote: ... an adapter out of an old presta style bike inner tube valve stem ...
Incredibly ingenious. =-)
I have not ridden a bike in about 35 years, much less repair or take one apart (something I did quite often at when in school). Could you elaborate on dimensions of this 'presta' style stem (outer diametre) and most important, on that pressure gauge (brand, price, etc.) you are using?
I have certain doubts as to the possibility of my being able to use this type of arrangement as the Cimbali PFs that came with my Junior D/1 are not like yours and only have a 7.0 mm hole with no threads.
Thanks for posting your brilliant idea.
Cheers,
CIV
Advertisement
Bluecold
#8: Post by Bluecold »
Presta is racing bike standard. Here in the netherlands we call it a french valve.
Either way, this is why I never throw away bike tubes. High quality butyl rubber with almost limitless uses.
LMWDP #232
#9: Post by DaveGrayson (original poster) »
CIV;
Like yours, my portafilter has a hole between 7 and 8 mm in diameter. The inside of the hole is unthreaded. The Presta valve stem has an outside diameter under 6 mm and it passes through the hole in the portafilter and is held in place with the nut that normally would fit on the valve stem if it were used on a bike (it comes with the tube). The inside is held in place by the flange of rubber left over after cutting out the valve stem. The gauge is a cheap bike gauge (15 bucks i think) that I got from www.mec.ca but should be available at anydedicated bike store. There are also cheap (2 bucks) adapters that screw onto presta stems that let you use normal tire gauges. Should be do-able for you too.
huw
#10: Post by huw »
That's brilliant!
I remembered your post when I was making my own portafilter gauge and cut a couple of rubber washers from an inner tube. No PTFE tape required...
Sealed watertight to 12 bar and easy to lightly unscrew from the portafilter to let some water leak out to simulate a shot.
Post Reply
