Effects of brew pressure on taste of espresso - Page 2
- cafeIKE
If you don't know gauge accuracy, you're adjusting blind. When the gauge 'ages', you may adjust needlessly.innermusic wrote:Should I be calculating brew pressure or backwash pressure? (About 1/2 bar difference on my machine.)
Lot's of experimenting w pressure, not profiling, many years ago led to the conclusion pressure is not crtical.
As Chris says, trust your taste.
PM me if you want borrow my gauge. You pay shipping & insurance. Both ways. .75kg
Ian's Coffee Stuff
- innermusic
Didn't realize that gauge could be inaccurate - I figured a gauge measures pressure. Babe in the woods that I am. Anyway, this morning I dropped down to 8 from previous 9ish and the difference in taste was huge, and terrible. Then I pushed it up to 9.6 same coffee and tasted much better. Low pressure was more dry. Awful.
Steve Holt
Trent Hills, Ontario Canada
Vivaldi II, Macap MXK, Baratza Vario
- cafeIKE
8 on the gauge could be below 7 on the puck... yuck
Ian's Coffee Stuff
- cannonfodder
Machine gauges are notoriously inaccurate. The capillary tube that feeds the gauge connects pretty far upstream from the grouphead will also affect the reading. Before I had the scace I simply screwed a pressure gauge onto one of my spare portafilters. Do not take the onboard gauges as being an exact measurement, but a general reference point for changes. Adjust the machine to your taste.
- AndyS
Doesn't that pressure regime describe most lever shots?cafeIKE wrote:8 on the gauge could be below 7 on the puck... yuck
-AndyS
VST refractometer/filter basket beta tester, no financial interest in the company
- HB
- Admin
No doubt that it would describe the majority of spring-powered lever espresso machines. I certainly wouldn't describe the espressos they produce as "yuck". In fact, for some coffees, I think spring-powered levers produce more nuanced, flavorful espressos than those produced by pump-powered machines.
- cafeIKE
Never measured pressure on lever.AndyS wrote:Does that pressure regime describe most lever shots?
Anything tried below 7 on a vibe pump was less than appealing.
Kinda a flat and 'oh so coffee'
The response was to a post with a vibe machine
Ian's Coffee Stuff
- AndyS
Espresso that tastes like coffee? Disgusting.cafeIKE wrote:Kinda a flat and 'oh so coffee'
-AndyS
- aecletec
I'm not sure about 'oh so' coffee (or what that is), but 'so so' coffee I can empathise with.
- HB
- Admin
Split follow-on discussion to Brew pressure gradient of espresso.
