What ratio citric acid / water to descale?
Can anyone tell me what amount of food grade citric acid to use per quart of water to descale my espresso machine? (It has a 2 quart tank I fill). (Ex: is it 1 Tablespoon per quart of water, or 1 teaspoon or whatever?)
Also, does it matter if you use the coarse or fine crystals in terms of dissolving?
I was also told food grade citric acid is called soursalt sometimes. Anyone know if that is correct?
Thanks!
Thanks!
- GVDub
I use 1.5-2 TBLs/liter, which works very well for me.
"Experience is a comb nature gives us after we are bald."
Chinese Proverb
LMWDP#238
Chinese Proverb
LMWDP#238
- another_jim
Yep. Go down to one tablespoon for aluminum parts. Also, don't freak if you see a greenish/bluish tinge when you rinse; that's normal for copper and brass parts.
Jim Schulman
- sweaner
Sour salt is another name for citric acid.
Scott
LMWDP #248
LMWDP #248
Jim,
What if it is "activated" citric acid? My machine is about 5 months old, we are in a hard water area. I have purchased Everpure descaler (activated citric acid) from espressoparts.com.
Still 1 Tbsl/Quart? Does it make a difference using "activated" for a Gaggia, with aluminum boiler? Thanks!
- another_jim
I'm not totally sure what "activated" means; but was told it is an additional ingredient that speeds up the action of the citric acid without increasing its strength. Using the standard amounts should work.
The issue with the Gaggia is preventing galvanic corrosion at the join between the lower brass part of the boiler and the upper aluminum part. Go a little easier on the citric concentration, and make sure you flush very thoroughly afterwards. Since the boiler is so small, the reduced concentration solution should still be effective.
Jim Schulman
Well, I have a Gaggia Classic. Do they all have aluminum? I thought I read the newer ones changed that.
Should I just play it safe and go with 1TBSP per Liter?
Does coarse or fine matter?
Thnks.
Thnks.
