Grinders: vertical vs. horizontal burr design - Page 2
- yakster
That's confusing since we're talking about burr orientation not shaft orientation, so I think you're saying that you prefer vertically oriented burrs.RTM wrote:My personal opinion is that horizontal motor shaft design of grinder is superior to vertical, soley for motor cleanliness.
-Chris
LMWDP # 272
LMWDP # 272
Why would vertical burrs necessarily wear out faster on one side? Yes, the beans fall only onto the face of one side of the burrs but isn't the entire diameter of the burrs rotating onto that side so that the entire burr set is engaged with the grinding all the time? The faster the rotation speed, the more this effect seems to me to be in operation...
LMWDP #729
- Ursego (original poster)
I noticed that too, so we should keep in mind: vertical burrs = horizontal motor/shaft.yakster wrote:That's confusing since we're talking about burr orientation not shaft orientation, so I think you're saying that you prefer vertically oriented burrs.
My bad- for some reason I was mixing up the rotational axis to the burr planeUrsego wrote:I noticed that too, so we should keep in mind: vertical burrs = horizontal motor/shaft.
With that I agree we should call it by the Burr plane
Horizontal shaft = vertical burrs
I've got a Mahlkönig Guatemala, spinning at a whopping ~2850 RPM. The grinder was used in a shop before I bought it, the kind unaware about maintenance .. The burr chamber was actually pretty much clean, but the bottom half of the static burr noticeably more worn. It had ground a lot of beans, at first I mistook the thick layer of caked on fines on the gasket for the actual gasketPrimacog wrote:Why would vertical burrs necessarily wear out faster on one side? Yes, the beans fall only onto the face of one side of the burrs but isn't the entire diameter of the burrs rotating onto that side so that the entire burr set is engaged with the grinding all the time? The faster the rotation speed, the more this effect seems to me to be in operation...
As for the topic, there are upsides and downsides with both orientations. I often wonder about how much pre-breaking the augers actually do, possibly not as much on some models as people seem to think. For home use I think the overall implementation is more important than burr orientation.
