Ideal espresso serving temperature - Page 2
I'd be interested in you drinking temperature for doubles if you have an instant read thermometer.baldheadracing wrote:
What I did notice in comparison to notNeutrals was the temperature difference when I pull doubles.
- baldheadracing
Average over two double shots (15g, 1:2) into separate cups (all in Celsius):
62 just after cup pulled from machine
Swirl vigorously for three-four seconds, then take measurement
51 after swirling
Give the espresso a sniff or two, then take measurement.
46 just before first sip
42 just before second sip
37 just before third sip (all gone).
My thermometer is not a Thermapen, but a thermometer with a metal tip like a Thermapen.
I would normally drink a little faster - the last sip was a little lukewarm for me. I'd also usually use the same cup for the second double shot, and drink slower.
51 after swirling
I'm a two sip guy with normally 18/33g shots. Your a bit warmer than I am (43-38C) but not by much. There's definitely something to be said about cooling espresso.baldheadracing wrote: 46 just before first sip
Nothing quite as dramatic as a Paragon brewer.
I believe WBC Gwilym Davies first hit upon the idea of letting your shot cool so you could taste more.
Me, too. I drink primarily espresso and usually let it cool before drinking in 2-3 sips. Hot-ish to warm... curious, I may Thermapen-it, but it's not consistent. The coffees I return to are the ones that still taste good when not hot. I look for coffees that are excellent at middle temperatures. In summer months I need espresso that is also good cold for iced americanos.
Back when I roasted for a shop (ancient history, I am not at all current with roasting) we cupped at several temps. The customer's last sip is likely to be cool, which is when their last impression occurs.
LMWDP #716: Spring comes, and the grass grows by itself.
