Roasting dark: 'S' curve vs constant declining RoR? - Page 6
- mkane
It may be easy for you to achieve a declining R0R but it sure as heck isn't for me. My batting avg. is about 500.
- Supporter ❤
Perhaps he meant "straight-forward" to mean, we have widely publicized guidelines to follow to get a good light/medium roast.
Yes, moreso this. There's so much VERY detailed discussion on those roasts. Less detailed info the further you go after first crack, less of those theory discussions of flavor impacts and energy modulation schemes, etc.
- drgary
To my reading, Alan's examples here imply an option of a fast start and a moderate finish. He writes, "I like to extend Maillard in lighter roasts to add complexity and shorten it in darker roasts to preserve some sweetness and acidity." Others have commented on the need to enter 1C at about 20°F BT ROR to proceed to 2C without stalling. That suggests tapering power during Maillard to a target BT ROR that would anticipate the desired ROR at 1C and beyond. (He describes that as a variable stage.) Again, I'll have to try it but could set up a crash and flick. I'll review earlier roast profiles to see what settings are needed to avoid that. For an S curve roast plan, you don't need to add heat but not attenuate it as much. This could be done by having a target ET and maintaining that. He also writes about the difficulty of avoiding increased ROR later in the roast and that his tasting of that result doesn't recommend it. I can see increasing fan speed at that point, but my roaster maintains enough heat that the fan needs to be pushed hard. (This is as much a note to myself as a comment for others.)
LMWDP#308
LMWDP#308
At a certain point you kind of just have to do the work of roasting, tasting, reviewing the data, and iterating on an idea. Progressive roasting exercises are an incredibly powerful training tool for that, but it can be difficult to justify at home roasting scale (much of the equipment is completely impractical for it and it's something that works out to be cheaper the more of the same coffee you're getting so financially this is unappealing at less than half bag quantities).
Another challenge when it comes to considerations of rate shaping is that temperature measurements are not the same across different machines. You can almost always find equivalent temperatures to construct a function taking temperatures on one machine and getting the temperatures that you'd read on a different one, but unless that looks like y = x + c (constant offset) it's going to be possible to construct a roasting plan that looks like a declining rate when viewed through the lens of one machine and not on a different one. It's not uncommon to see larger differences among machines at hotter temperatures (people who do this work more than I do have reported that sometimes the constant offset case exists, but in my experience it's almost always some kind of non-linear curve), which makes rate based considerations considerably less useful (or at least obviously not universal). Time within ranges combined with a measured roast level are, I think, a more useful framing unless everybody is talking about roasts on the same machine, though it's hard to justify the expense of that for a home roaster (or even most small commercial roasters).
- drgary
Neal, thank you for explaining this recommendation so well.N3Roaster wrote:Time within ranges combined with a measured roast level are, I think, a more useful framing unless everybody is talking about roasts on the same machine, though it's hard to justify the expense of that for a home roaster (or even most small commercial roasters).
LMWDP#308
LMWDP#308
- mkane
I switch between 2mm & 3mm BT probes mainly because I have 2 spots on the front of the machine with probes in place. The 2mm is in a location I think is optimum, darn near right @ 7:00. The 3mm is not so good. To close to the centerline. Bean temps are wildly different between the two. I prefer the 2mm probe as I think it tells the truth.
I like to focus on ET and percentages in each stage when comparing someone else's profile.
Roasted this Guatemala Huehuetenango Guaya'b from Happy Mug the other day. This is dark for me, as it goes to second crack. Maybe closer to a traditional medium.
I purposely cut gas into yellow to try to get a more constant RoR around 18-20 from then into first crack and trying to keep it running fairly quickly through first. Brewed up a V60 on just over a day's rest and it's decent. At first sip I thought it was gonna be disgusting bitter trash like my average second crack attempt but it ended up tasting alright. Though I think I prefer this bean roasted 20°F so far, but I'm not too disappointed by this attempt.
- Supporter ❤
I've been having some great tasting darker roasts by following the declining RoR technique but shifting RoR up. With a typical light/medium roast I'll enter FC around 15F/min. With a darker roast I'll enter FC at 20-22F/min. That gives me more RoR to steadily decline from during FC and postFC while also giving me enough momentum to drop heat while not getting an excessively long roast. I've been pulling off just after SC.
I've found that it is hard to keep it steadily declining after FC ends. RoR likes to flatten out even with gas cut but the coffee tastes great. No bitterness even at that dark of a roast. I'm still perfecting my profile I'm using. I've had to balance, with some coffees, the effect of using more momentum going into FC causing the slight rise and fall of RoR. Rao discusses some tricks of cutting gas and then relighting to eliminate those anomalies but I may play with using the diffuser there.
Keeping the RoR from not increasing after FC is VERY important for the coffees I've roasted so far. Even a little rise after FC end will sprinkle that roast note in whereas the ones that stay flat or decrease after FC are pure chocolate.
I'll post some graphs later.
Roasting on a Quest I seem to always get a crash and flick right after FC. Given that it's electric heating elements I've been trying to anticipate this since I can let just cut the heat.
I want to compare a declining ROR to what I have been getting but first I need to get there. Should I add more heat early on then cut heat right around FC?
