Leaky Rocket Mozzafiato Evo R - Page 2
With the new valve in place, no more water leaking but..... it seems the valve is not shutting well. If I lift the lever, I have some slow stream of water coming through the brew head even with machine off, pointing me to conclusion valve is not shutting well.
I guess these valves are directional (there are no arrows on the old one for sure) and if connected backwards the pressure from inlet can push the plunger thus negating it working as it should.
On the other side, I got myself a little pre-infusion feature by mistake
If these are directional, what are the downsides if I leave it like this?
TYA
TYA
