Ponte Vecchio Export: how is the pressurestat connected to the bottom plate [SOLVED] - Page 2
Maybe. But to be clear, the pipe didn't go through before I heated the plate. Because the plate has shrunk, it's now fixed.
OK. Hopefully the hole won't expand when the boiler heats up...but I think you'll be OK because there IS solder in that joint, and that is what seals it. Show us a picture of your machine when it's all fixed up!
