La Marzocco Advanced Precision Basket. Is it the same as Strada basket?
LM sells them for only $11.79:
https://home.lamarzoccousa.com/product/17g-basket/
Are they good? Are they the same as the Strada baskets? I've read they are produced at the same factory as VST baskets. Are they comparable to VST?
To the eye, by weight, by all the means I can measure them with, they appear to be identical other than the laser etch and the quality report.
- cycomachead
When I ordered Strada basked from LM Italy (with some other stuff), they came with a paper verifying test results and they have a bar code that the ones that came with my Linea Mini don't have.
The Strada ones _seem_ to have a very slightly different coating, but I'm not sure. I haven't been able to notice performance differences, but I do use the Strada basket every day--just because I paid for it.
I just got a new GS3, it came with some baskets that look pretty simple, not as heavy as VST, and not polished. Nothing is written on them. The GS3 operating manual says they are 'advanced precision', but I am not sure...
Should I switch back to VST?
How much did you pay for the Strada baskets, I am curious.
I was curious - and I bought a Strada basket from LM Parts. It was $35 or so.
In every respect, it was completely identical to the "advanced precision" basket of the same size supplied with my Linea Mini. I have a VST basket that appears to be identical in construction, other than being a ridge-less 20g.
The Strada came with the same sort of certificate that the VST basket comes with. I believe both are manufactured by VST or at least in the same manner if not by the same manufacturer.
There's no guarantee that this remains the same or will in the future.
Link to LM's data on basket types:
http://lamarzoccousa.com/docs/tb/LM-Basket-Guide.pdf
How does the espresso taste? Honestly. Does it really matter what the basket is?
LMWDP #544
Yes, I can explain my question. The operating manual of GS3 mentions the machine is shipped with the 'advanced precision' baskets. Moreover, it is convenient to have LM 7gm, 14 g, 17g, 21g. The full range. I've read they are the same as VST, but without certification. It's OK, the chances are they are of high quality. But from what I see, they look different, not polished, lighter, etc. There is no sigh 'advanced precision" on them. If they are not 'advanced precision', I could try to ask LM to replace them.
I just got my machine (and baskets) yesterday, so it is too early to make any conclusions. What I see now is that VST's require finer grind, but I am not sure yet. In a couple of shots I could see that the time of extraction for VST's is faster. So, I need to grind finer with VST. That is why it is difficult to compare the taste.
They look different than mine. Polished. Can you please show a picture of yours? If it is not too burdensome.. thanks!nuketopia wrote: Link to LM's data on basket types:
- Peppersass
- Supporter ❤
LM Strada and LM Advanced Precision baskets are made in the same factory as VST baskets, under license from VST.
LM Strada baskets are essentially identical to VST baskets. The only difference is that VST uses an automated, high-volume optical inspection process, while LM uses a manual optical inspection process. Thus LM can't produce Strada baskets in high volumes at reasonable margins, and they supply them only with their most expensive machines.
LM Advanced Precision Baskets are manufactured the same way, but the optical scanning process isn't used. Therefore LM's margins on these baskets make them more suitable for inclusion with their lower-priced machines and higher-volume machines. But they're not identical in quality or consistency to Strada and VST baskets.
You can find information on the subject from LM here.
