La Marzocco Linea Mini Microfoam Struggles - Page 4
I use the standard LM tip and have the steam boiler set at 2 bar. I use a 600 mL jug and find that the quality of the microfoam is excellent other than one thing... I get a very small blob (about the size of a dime) of thicker foam in the very middle of the jug... I can get rid of it by using the milk sharing technique (i.e. pouring the milk into another jug) but don't think that I should need to. Any thoughts on what I'm doing wrong? It has to be me and not the machine.
LMWDP #602
Thats the same setup as me including machine, pressure setting and tip. Do you swirl before pouring?
Certainly do swirl before pouring. The thicker foam blob almost looks like it becomes more pronounced after a swirl!
LMWDP #602
- bluesman
You may be stretching a few seconds too long. That "blob" is usually a sign of too much aeration, in my experience.kwantfm wrote:I use the standard LM tip and have the steam boiler set at 2 bar. I use a 600 mL jug and find that the quality of the microfoam is excellent other than one thing... I get a very small blob (about the size of a dime) of thicker foam in the very middle of the jug... I can get rid of it by using the milk sharing technique (i.e. pouring the milk into another jug) but don't think that I should need to. Any thoughts on what I'm doing wrong? It has to be me and not the machine.
Blob almost certainly means too much air. Another tip I learned from Zach at La Marzocco Home last week: the introduction of air should be in the *smallest* increments. You should hear a "tsk-tsk" rather than a "ch-ch" (if that makes sense). The sound should be really sharp, like a cutting or tearing. I thought I had been doing this along but realized that if I anchor the pitcher against the wand, I'm able to *barely* lower the other side and get that sound of small slivers of air. Now my milk is legitimately precise, like something out of a latte art video. You can basically draw with it. Using the Slayer 1.0 tip, FWIW.
Thanks all, too much air was exactly the right diagnosis. I find this quite embarrassing given I've been steaming milk successfully for over a decade. Much better results this morning!
LMWDP #602
