Drop in brew pressure, but grinding finer stops flow?
Hello,
I am using a Bezzera Mitica and a Quamar grinder.
Using the blind filter the machine puts out 9 bar of pressure, constantly.
Now, when I grind about 18 grams of coffee, and turn the machine on, the pressure rises to this 9 bar, but drops after a few seconds to about 6-7 bar. I figured that I need to adjust my grind to be more fine. But when I do grind one stop finer, there is no flow for a long time and I get nowhere near the 20-25 ml of espresso in a shot of say 25 sec.
Any suggestions?
Thanks in advance.
Regards,
Rein
Any suggestions?
Thanks in advance.
Regards,
Rein
Read through this thread: Quamar M80e - grind fine level
Take a look at your burrs and see if you have the correct ones.
- sweaner
BUT...how is the espresso?
Do are you using a naked PF? You may be developing channeling giving the pressure drop.
Scott
LMWDP #248
LMWDP #248
Have emptied the grinder, cleaned it, used some pulygrind.
Refilled the grinder with some coffee; and it looks like it has solved the problem
I also bought a naked pf; and no channeling issues
Espresso tastes great again.
Thanks for the suggestions, sweaner and Bill33525!
