Help Rewiring Nuova Simonelli MDX
Hello!
I bought this for a song knowing it wasn't in working condition.
The seller did not have any info on the history other than the doser counter is at about 4,100.
I stripped it down last night to clean and diagnosis, but to my surprise nothing inside was hooked up and it looks like one wire was cut, and a switch is missing on the side.
Does anyone have a diagram how these should be wired?
Many thanks in advance-
I own one of these, its in my basement on a shelf, disassembled. If you don't get a wiring diagram posted, I would be happy to snap some images of the wires, or message you offline about what goes where.
Mine suffers from mal-alignment, which is why I took it apart. The way in which the motor and lower burr is suspended doesn't appear to offer a rigid framework for making the burr surfaces parallel, so I abandoned it. I hold onto it, just in case I can invent a new frame structure with the existing parts. In the meanwhile, the Mazzer engineering is just superior.
- redbone
You can try these links. Units may vary depending on year and model variants throughout the years.
https://www.espressoparts.com/parts/esp ... nder-parts
http://www.espresso-solutions.co.uk/pag ... inders/01/
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Thanks. I found these already and they unfortunately don't show where the wires need to go.
Well, here's an image I found -
Nuova Simonelli MDX - Mazzer Super Jolly alternative
White wires go to the switch
red and blue are in and out of the capacitor
You would have to use a multimeter to determine the correct poles.
But, I'll get you the rest of what you need.
What I see on mine is that the white and black from the power plug go into one side of the switch, and the green wire is ground. It has a loop end on it for a screw.
Red and Blue are confirmed as going into/out of the capacitor.
The reset button has a black going into one side, that comes from the power switch's power out side;
and the other side of the reset button leads directly to the motor, that wire is brown.
sprint jinx wrote:What I see on mine is that the white and black from the power plug go into one side of the switch, and the green wire is ground. It has a loop end on it for a screw.
This is perfect, thank you.
I got it re-wired and running.
All it needed was a new switch.
