Have perfect valve for Prestina to auto fill. Where to put probe?
Has anyone converted a Prestina to auto fill? Where would you locate the probe?
Do you tap the sight tube fitting or the boiler lid? That stud directly above the sight fitting seems prohibitive.
I have the Prestina and a fill valve that has a manual section and a solenoid section.
The plumbing is simple and the mount will be easy but there seems no good location for the probe.
- drgary
David:
I think they would have seen machines fitted this way on Kaffee-Netz. If you search Prestina there you will probably come up with photos.
https://www.kaffee-netz.de/
Also search Home-Barista for Prestina autofill. More than one thread showed in the search, including this one, which may give you clues.
Conti Prestina, The Netherlands
LMWDP#308
LMWDP#308
