Scratches on filter basket
Hi all, I have scratches on my filter basket because i used a spoon to scoop the coffee puck as i had no knockbox then. Will this affect the intregrity of the holes?
- TomC
Not likely.
If it's a bottomless portafilter, you could monitor it yourself. I think you'd have to significantly dent or actual mar a few holes to cause much of a problem.And even that might not be the worst thing ever.
- cannonfodder
You would have to gouge it pretty good to really impact it. Surface scuffs should be minimal. If you take say a half inch dowel rod, a small plastic trash can, a half inch drill bit, drill a hole on either side of the trash can and stick the dowel through it, you have a cheap gets it done knock box.
