Ponte Vecchio Lusso, case removal
Hi All, I can't figure out how to remove the side water and steam knobs. Anybody in the know?
- peacecup
Mine have screws in the center. Unscrew these, then pull them off. If they stick you may need to GENTLY pry them off with a screwdriver blade.
LMWDP #049
mines are pentagram design with no visible screws anywhere. At first I assumed they slide on and off, but any attempt to pry them off risk to deform the metal box, it's so hard.
- peacecup
Better write to LaMacchinaCaffe - they are good customer service and will know how to do it:
https://www.lamacchinadelcaffe.com/rica ... cchio.html
It looks in the picture on that page that there may be a small cap covering the screw head in the new ones?
LMWDP #049
Yes, looks the center of the knob is a cap cover. On mine they fit so snugly I can't get them off.
- peacecup
could drill a small hole in them and insert a small screw. They are not really needed anyway.
LMWDP #049
The machine is brand new under warranty, and I am afraid to go the brutal way
In the end drilled a hole and pulled out the caps. Thanks for advice.
Because of the myths concerning Ponte Vecchio quality control (or the lack of) I feel obliged to mention that my Lusso arrived excellently packaged, and in full working order. Inside, apart from the small chaos of cables, the welds are exemplary, and I hope the machine to last. The cosmetic quality on the outside is very good, but, of course, it won't match the cosmetics of machines costing 300% more or produced in industrial way. Mine was made in effect to order (two weeks waiting time) in what I consider an artisan workshop.
The machine was supplied by LaMacchinaCaffe.com to whom I like to publicly thank for the smooth transaction.
P.S. Amusingly the Ponte Vecchio supplied plastic tamper match better the baskets, compared to Motta which I plan to return. The machine also came with not two, but three baskets, the third being single and shallow for, I guess, espresso leggero.
- peacecup
My Sama Lusso, of basically the same design and quality, is probably more than 30 years old. I just empty it every morning, fill it, and pull shots all day. Once every 2-3 years I might need to change the piston seals or the steam wand washers (to prevent drips).
What amazes me most is that I love the espresso as much or more today than I did 10 years ago when I first got my Export. Tonight's after-dinner espresso was sublime. I suppose I could find a machine that makes better espresso, but it wouldn't be easy. My results the past 10 years have been so good that I have very little incentive to try other machines.
LMWDP #049
