Water pressure restrictions and Flojet system - Page 3
Great! I need to mount all of my parts like that, I've left it a messy loose arrangement.kiley76 wrote:This is the system I installed to draw from a 5 gallon reservoir, I will still be adding a backflow preventer, but everything is working now ...thanks for all the help, couldn't have done it without you guys
<image>
So the round valve in the middle of the board is to adjust the pressure? What part is that?
LMWDP #371
Cool. I am going to get the regulator and gauge, my setup is almost identical to yours, minus those two parts. Being plumbed in is the best upgrade I have ever made to my coffee bar, always on and always ready to make shots.kiley76 wrote:The white one is the pressure regulator, I have it dialed down to 22 PSI which is what my machine calls for. Accumulator tank was key, and having the Gauge to read
my actual pressure is awfully nice
<image>
LMWDP #371
I am blessed with a beautiful home, unfortunately there are crazy limitations that keep me from being able to plumb this in.
In an Ideal World, I run this rig for a few months make sure I'm a hundred percent behind it and then sell it to get a smaller unit for my home. Next weekend I'll be running 220 in an effort to move it into the house and out of the garage, just in time for winter...
Hi all, I'm new here!
I'm trying to read up and understand how to install Flojet (Bottled Water System) + Accumulator Tank for my LM GS3 MP version.
Is it correct that I need a pressure regulator to increase the water pressure (PSI/Bar) into the espresso machine?
- spressomon
Actually, a regulator cannot increase the pressure to the espresso machine, only decrease it from the value that the Flo Jet attains. For preinfusion and supply to the boiler this should work fine.
Suffering from EAS (Espresso Acquisition Syndrome)
LMWDP #586
LMWDP #586
But out from the Flojet, it's about 2+ bar of pressure. If the regulator is only meant to decrease the value.. means it will be lower than 2 bar?
I read somewhere that the LM GS3 MP version will need min of 3-4 bar pressure for the pre-infusion line pressure to work. How do I achieve this?
- spressomon
Swap in a different pump if you need higher pump output pressure. I'm using the Aquatec 5853-7E12-J524 1.7 GPM 60 PSI 3/8 inch JG 120V Delivery/Demand Pump. No issues.
No Espresso = Depresso
