I need suggestion for my roaster design
i made my own 1kg roaster, the cylinder drum diameter 22cm, lenght 16cm, i used 77rpm, i need suggestion for heat source, cylinder type, and exhaust mechanism, should i make it direct heat or air flow?
please help me
please help me
Direct heat applied to the drum, airflow to help modulate temperature and remove chaff. The beans will do both convection and conductive heating.
I used a infrared propane core from a BBQ
Also agree with above Aitken flow is a must for temp control and chaff separation
Bill
Bill
