Older faema group info
What is the dose used in a feama urania or president?
What is the average breverage weight out of it?
What is the portafilter size?
- dominico
My typical dose range is between 14 to 18 grams.
Beverage weight varies depending on your dose, grind, pre-infusion routine, but I'd call a very rough average to be 35 to 45 grams. I usually cut the shots around 30g unless I am dosing up to 18g.
The portafilter is a standard "e61" 58mm portafilter.
https://bit.ly/3N1bhPR
