Confused on shot timing.
So I am a little confused about shot timing. I have seen both, timing starts when pump starts, and timing starts at the first drip from portafilter. For me first drip can be anywhere from 5 to 10 seconds depending on grind. So which way is best?
From when you switch on the pump .. this is the way all times are communicated , so keep it consistent .
Don't tie yourself up in killing a shot by time , use a brew ratio ( weight ) instead
I am now pulling by ratio 18 grams coffee in to 36 grams espresso out. But I thought this should all happen in 25 to 30 seconds. So it seems they are related.
What brought this about was some Vivace Dolce I am having trouble with. 18 grams in, 36 to 39 grams out, in 25 to 30 seconds. Brew temp 201. It always taste smoky, and burnt.
- HB
- Admin
Dwell time: Can someone explain? elaborates on this point. For espresso machines that have long dwell times, Jim proposed that for comparison's sake, divide by two.Stryker03 wrote:So I am a little confused about shot timing. I have seen both, timing starts when pump starts, and timing starts at the first drip from portafilter.
If it's a dark roasted coffee, lower the temperature and decrease the dose. Espresso 101: How to Adjust Dose and Grind Setting by Taste offers more specifics.Stryker03 wrote:It always taste smoky, and burnt.
If you are brewing by ratio , brew by ratio not time ...Stryker03 wrote:I am now pulling by ratio 18 grams coffee in to 36 grams espresso out. But I thought this should all happen in 25 to 30 seconds. So it seems they are related.
Note the time for sure, don't adjust a shot by the time it takes to pull ....adjust via taste you find ...
I have had shot from 20-45 seconds that have been tasty btw...
Thanks for the input. I have already started lowering the brew temp. Will see how it goes.
I've recently started lowering my brew temperature as well, it really improves the shots. Took a bit of experimenting, but I learned the best ways.
