Fast extractions even at finest grind - Page 2
Thanks Andrew,
My PID reads 200F then flashes to like 257 or so I believe. The 200 is what the brew boiler temperature reads. What is the offset?
http://www.profitec-espresso.com/filead ... glisch.pdf
There are several threads regarding this. You will need to change e1 to 25 if you use F instead of C. The default published values in F had the wrong offset.
Profitec Pro 700: brew temperature offset
Just check yours. Maybe it is already correct who knows?
Andrew
