Update on the $25.00 1973 La Pavoni Europiccola
tmpass
#1: Post by tmpass »
So a few months back I posted about my $25 eBay find, a vintage euro. I took a chance, got it delivered from Italy and replaced the sight glass and its gaskets, I added a cheap pressure gauge because the sight glass cap was missing. No other gaskets were replaced. This thing has been flawless since. It is a 220 model so it takes some time to heat up, but once I got the grind dialed in, the shots have been great. I just eyeball the coffee quantity.. But after a few months I don't really need to weigh or change anything. I find now the pressure gauge is also not needed, good coffee can be produced just by listening to the machine.
I lurked here quite a bit reading all the brewing and technical posts and learned a lot, so thank you.
I also found a local roaster so my coffee is right down the road. The guy is great and really into perfecting his roasts, give him a try if you are in Boston metro west area http://www.bostoncommoncoffee.com. He is located in Hopedale, MA but has retails stores in Boston as well.
That's the only drip tray I have, from another sad Euro I picked up locally. I also would like to find an emblem.... The red one for the front, but not confident on that.
Chert
#2: Post by Chert »
Maybe it is the angle, but that bell looks to me like a millennium style. Is there a plastic liner? Is that basket 49 mm or 51?
You could rewire the thing to plug into your dryer outlet. Then it would heat up fast!
LMWDP #198
grog
#3: Post by grog »
'73 should still have the brass sleeve, but with removable shower screen - best of both worlds.
Check out George Howell coffees too. One of
my favorite roasters anywhere - I still order his stuff out here in Seattle, six years after moving from Boston.
http://www.georgehowellcoffee.com/terroir-coffee/
LMWDP #514
dominico
#4: Post by dominico »
It's most certainly a Gen 1.
The original group looks very similar to the millenium group.
You can tell the difference because
  • The group screws into the boiler, there are no bolts on either side
  • The male threads are on the boiler rather than on the cap
It will be a 49mm portafilter.
Also to note, these originals didn't have a "drip tray" just a slightly recessed surface.
You can see the progression of the Europiccola here:
http://www.francescoceccarelli.eu/lapavoni.htm
https://bit.ly/3N1bhPR
CoffeeBar
#5: Post by CoffeeBar »
Nice looking machine. Yes, I can confirm this this pre-mill model. :D
DanoM
#6: Post by DanoM »
Absolutely beautiful! I love those old boiler caps on these models.
Now where can I get mine!!!
LMWDP #445
