Airflow effect
Hi just wondering why is it good keep airflow at minimum during first part of roast? What affect does airflow have for a dense bean and low density bean?
- turtle
I keep the dampers closed until I get to the point where the beans start releasing moisture (usually 225-250 degrees). I want to get from dump to the start of dry as quickly as possible without scorching the beans
Mick - Drinking in life one cup at a time
I'd rather be roasting coffee
- JK
When you charge beans they start releasing moisture..
With low air flow they are in a steam bath like environment and transfer more heat to each other more easily..
When they turn yellow you increase air and just before 1C you increase air again..
I'm on a Mission from God!
