Pump pressure on Rocket Evo V2 and effect on shot
Hi all,
After lots of reading about lower brewing pressure when pulling shots, I've decided to test it on my own.
I have a Rocket Evo V2 with a rotary pump that was running at 9 Bar of pressure at the gauge.
Decided to lower it to 6 Bar of pressure at the gauge. I've adjusted it with the blind basket and the reading on the gauge.
Pulled a shot with the exact same adjustments on the grinder and dose.
I was pretty surprised that the shot pulled at the same rate that when I was pulling at 9 Bar ?!?! Around 27-30 seconds for the same yield.
Am I missing something here ? I was expecting the shot to take more time to pull the same amount since there is a 40 psi difference.
Thanks
Jo
Thanks
Jo
Might have missed something but that doesn't really explain why this would be happening ?
Also did some test and in 30 seconds, I'm getting around 325ml.
- Chert
30 seconds just flow no PF in place yields 325 ml - is that what you mean?
LMWDP #198
Yes sorry, missing some details
Did the test with 9 Bar of pressure and I'm getting 405-410ml in 30 seconds.
My guess is that higher pressure compacts the grinds more and this reduces flow - roughly canceling the normal effect of higher pressure.Might have missed something but that doesn't really explain why this would be happening ?
