LIDO ET vs. LIDO 3 grind settings
Hi all,
I am deciding between the Lido 3 and the ET for grinding for Espro Press, V60, and Kalita Wave at work. I know the ET is usually for espresso, bit since the grind range is the same, it might be nice having the finer adjustments.
I found a manual for the Lido 3 on line but have not been able to find one for the ET. The manual for the Lido 3 says:
- Espresso range is about 2-4 marks from zero.
- Drip range is about 4-12 marks from zero (depends on method).
- Full Immersion (Press - Coarse) range is about 12 to 2 full rotations depending on your method.
Can someone that has the ET (or the E) tell me what the manual has for suggested grind settings so I can compare how different the settings are.
Thanks.
Thanks.
E and ET have identical adjustment mechanism and burrs. http://www.oehandgrinders.com/LIDO-Grin ... _47-1.html
